Author Topic: FJM spindles  (Read 1154 times)
Offline the_engineers
FJM spindles
« on: January 26, 2010 - 10:11:28 PM »
There was extensive discussion about the fact that these will work, but which is better...FJM or 73+ A spindles?  I know there's a slight handling advantage with the FJM set-up.
I have A/E spindles right now, but a set of FJM's fell into my lap.  I've got some upcoming suspension work, so should I swap?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline cudazappa
Re: FJM spindles
« Reply #1 on: January 26, 2010 - 10:57:45 PM »
the three advantages of the FJM spindles off the top of my head are:
Taller - better geometry to take advantage of
Lighter - less unsprung weight!
Use the 73+ rotors - Cheaper and readily available.
FWIW: my 71 Challenger has stock discs and sway bar (HD package on a 318 car).  I'm upgrading to the FJM rotors (mine are off a 79 300, late Bs use the same one) when I do the t-bars and upgrading to the 11.75" discs. :2cents:
2015 Dart GT - Daily Driver
Re: FJM spindles
« Reply #2 on: January 26, 2010 - 11:05:56 PM »
I bought some this summer at Pick n Pull myself. Off a 76 Cordoba.
Offline autoxcuda
    • Spring Fling
Re: FJM spindles
« Reply #3 on: January 29, 2010 - 03:11:40 PM »
No, not worth the effort.
One possible issue  is the backspace on 17" rims. Since the spindles are a little taller, if you are running over 5" backspacing in the front there may be a interference issue with the upper ball joint. Something to think about.
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
