Author Topic: I need pics. Chally with 17" rims.. ???  (Read 2691 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: January 27, 2010 - 04:25:02 AM »
I run 245 / 45 -17 in back of my Chall, - but want some tires with a little more rubber (sidewall)..
Anyone runs 265 / 50 or 255 / 60 or, or, or..???
Offline 422STROKER
  • Member Since 6/3/06
Re: I need pics. Chally with 17" rims.. ???
« Reply #1 on: January 27, 2010 - 06:06:09 AM »
I run 255/45/17 but thought of the 255/50/17 for more height while fitting on the 8" rims.
Tom
Trunk is loaded down in this pic coming home from Carlilse last year.
Here is another empty.
Tom
Offline 73Chally
« Reply #2 on: January 27, 2010 - 08:49:42 AM »
I run 255/60-17 on 17x8 wheels on the rear, and 235/60-17 on 17x7 wheels on the front.  Plenty of clearance.
« Last Edit: January 27, 2010 - 08:54:37 AM by 73Chally »
Offline drewcrane
« Reply #3 on: January 27, 2010 - 10:49:10 AM »
i managed to get a 275 /40 17 all the way around,
i have to use a link for pix its on face book but this is the best pic i can find that shows the profile, i feel this is about as big as you can get with an 8 inch rim/wheel
http://www.facebook.com/home.php#/photo.php?pid=3664309&id=156414868766
you also have this thread
http://www.cuda-challenger.com/cc/index.php?topic=42140.0
« Last Edit: January 27, 2010 - 10:51:08 AM by drewcrane »
Offline Kapteenikosmos
« Reply #4 on: January 27, 2010 - 11:44:46 AM »
275/50-17 at rear. Pretty rare tire size and I only found two "cheapish" manufacturers for these. Nitto and Falken. Mine are Falken's.
The height the tires is about the same as the very popular ebody size for rears: 275/60-15
The pics aren't the best but might give some idea. It's missing still lots of parts and also I don't think that the springs are yet settled so it sits quite high.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #5 on: January 27, 2010 - 01:14:54 PM »
Kapteenikosmos
275/50-17 at rear.
What rim, and backspace.. ???
« Reply #6 on: January 27, 2010 - 01:51:03 PM »
17x9.5" with 5.5" backspace, centerline daggers.
I have Dr diff 1" relocation kit with standard width E-body rear (perches cut and rewelded). It's pushing bit close to the fender lip but there is a plenty of room to the leaf spring. So if it hits the fender lip on full load I'll swap in an b-body rear which is bit narrower.
Ville
Offline dwbiggs
« Reply #7 on: February 09, 2010 - 11:02:24 PM »
255/50-17 rear, 235/50-17 front
