Author Topic: Oil on driver side rear brakes only  (Read 643 times)
Offline cuda-cable
  • MOPAR or no car
« on: January 27, 2010 - 10:13:06 AM »
Doing some winter pm on my Cuda, pulled the rear wheels and have some diff oil on the driver side brakes. I'm planning to change the seal in the axle tube but have seen some where that the end play also affect if the seal leaks or not. How's that work and whats the cure if it?
Offline 426HEMI
Re: Oil on driver side rear brakes only
« Reply #1 on: January 27, 2010 - 10:24:16 AM »
Which rear axle do you have?
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #2 on: January 27, 2010 - 10:52:48 AM »
if the end play is excessive the bearing will not sit in the center of the bearing cup & will load the brgs higher int he housing leaving a gap at the bottom of the sesal for the oil to leak out , the end play should be in the .008 range . I doubt your leak is caused by excessive play or both sides would leak
Offline cuda-cable
  • MOPAR or no car
« Reply #3 on: January 27, 2010 - 12:23:37 PM »
thx for the quick reply......I get the picture so with excess end play the axle is not centred in the seal.......thx much, i'll try a new seal.....dk
Offline rallye73
  • Model cars for the big boys!!
« Reply #4 on: January 27, 2010 - 06:59:02 PM »
Could also be a clogged vent on the housing.
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
