Author Topic: Hitech LED Products - '72-'74 Chally  (Read 1848 times)
Offline dwbiggs
Re: Hitech LED Products - '72-'74 Chally
« Reply #1 on: January 28, 2010 - 02:17:30 PM »
I think it would look pretty good.
What I would like to see is someone relocate the reverse lights and then have two tail lights per side.  I wonder if the passengers side tail light lense would fit in place of the drivers side reverse light lense?
Offline erat340
« Reply #2 on: January 28, 2010 - 03:48:40 PM »
I have. tried to fit Rh tail lens to LH reverse housing...no go, different shape/size.What I did is remove stepped reflector, cut piece of red flat plastic stock and glue into center. Then, splice in two more sockets. Havent found way to use B/U lamps yet.
Offline dwbiggs
« Reply #3 on: January 28, 2010 - 04:08:31 PM »
This guy apparently used a modified Chevelle setup...
« Reply #4 on: January 28, 2010 - 04:13:53 PM »
Now that you posted it, I have seen that video before.  It looks really good.
Do you have any pics of your double tail light mod?
Offline stein
« Reply #5 on: January 29, 2010 - 01:02:07 PM »
I added the LED lights to my 72 Challenger. They were well worth the money spent to get such a bright tail light. The added safty and brighter back up lights makes it a no brainer.
Challenger owner since 1977
Offline Chlngrcrzy
« Reply #6 on: January 29, 2010 - 08:02:34 PM »
Impressive. I will have to earmark this for a later look see.  :popcorn:
