Author Topic: 1969 440 HP Motor  (Read 1414 times)
Offline challengerx
1969 440 HP Motor
« on: January 29, 2010 - 10:55:35 PM »
I have a E440 Hp, 1969 440 hp engine with a build date of 11-15-68. The motor has no heads,intake or pan, the rest of it is stilll together but needs a rebuild. I believe it is std. bore.
Re: 1969 440 HP Motor
« Reply #1 on: January 29, 2010 - 11:42:09 PM »
Are you selling it locally? Then you should research on Craigslist based on where you live and surrounding areas what similiar ones are going for. I've looked at other locations what stuff sells for and it varies across the U.S. Without heads, I don't think it's worth very much.
Alaskan_TA
« Reply #2 on: January 29, 2010 - 11:49:28 PM »
What is the VIN number on it?
Offline Jimmy
  • THE Challenge(r)
« Reply #3 on: January 30, 2010 - 09:17:30 AM »
I just bought a complete 1971 440 for $300.
1973 Challenger w/440
1967 Camaro RS w/502
1967 Mustang w/302
1965 Ford F100 w/429
Offline 73Chally
« Reply #4 on: January 30, 2010 - 09:48:52 AM »
A good 68 block might be worth $400 depending on where you are.
