Author Topic: Your recommendation for tourque covtere stall range (440, 727)  (Read 1292 times)
Offline DocMel
« on: January 30, 2010 - 07:35:41 PM »
Its a 440, 800 cfm carb.  Headers, magna flow dual exh
Current cam specs are (ebrock perpfmer rpm 7194)
Hydraulic flat tappet
Basic Operating RPM Range  1,500-6,500
Intake Duration at 050 inch Lift  238
Exhaust Duration at 050 inch Lift  246
Duration at 050 inch Lift  238 int./246 exh.
Advertised Intake Duration  300
Advertised Exhaust Duration  308
Advertised Duration  300 int./308 exh.
Intake Valve Lift with Factory Rocker Arm Ratio  0.480 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio  0.495 in.
Valve Lift with Factory Rocker Arm Ratio  0.480 int./0.495 exh. lift
Lobe Separation (degrees)  110
I'm a daily driver guy, but like to hit it at times.
So based on the above, what RPM range tourque converter do you recommend?
Re: Your recommendation for tourque covtere stall range (440, 727)
« Reply #1 on: January 30, 2010 - 08:00:17 PM »
The boys down at ACC can make a recommendation...here is form to fill out
http://www.accperformance.com/Order/index.html
I emailed this vendor & got a very good price quoted
http://www.murphysautomotive.com/
« Last Edit: January 30, 2010 - 08:05:16 PM by Bullitt- »
« Reply #2 on: January 30, 2010 - 08:53:39 PM »
 :popcorn: I have a similiar combo too?
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #3 on: January 30, 2010 - 09:50:50 PM »
You can also go to www.tciauto.com. Good info there even if you don't buy their products!!! They have very well laid out tech articles and a tech forum. If you give them your engine specs, they will recommend a suitable torque converter. They make an excellent torque converter. I have the "Ultimate Street Fighter" (TCI Torque convertor) in my car and it performs flawlessly!!
                                               Matt B.
Matt
