After taking my column apart, the yellow start wire looked like it was very close to having problems. I then looked at two spare ign switches I have from donor cars and they are similar.
Once the yellow wire grounds, you can't start the car any more and will burn up the fusible link. (no fuses in the start cct). Just thought I'd post so anyone redoing their column could check to make sure theirs is ok before reassembly.
