Author Topic: lets play name that power steering pump..please  (Read 973 times)
Offline challngd73
« on: February 02, 2010 - 11:52:56 AM »
Ok, I am trying to replace my power steering pump, problem is, mine doesnt look like the photos I see of the saginaw or federal.  so I need to know what I have, and if I can just replace it with a saginaw.  thanks for playing...
Offline challngd73
Re: lets play name that power steering pump..please
« Reply #1 on: February 02, 2010 - 12:08:40 PM »
after looking at it, I think it might be a federal, but why is the filler tube so long?
« Reply #2 on: February 02, 2010 - 12:39:33 PM »
I don't know for sure but it looks like a pump that would've been from a van. The long neck in a tight area would be why. What year.... no idea.
Offline challngd73
« Reply #3 on: February 02, 2010 - 12:44:30 PM »
well, the motor is a 72.  can I just use a federal pump for a 73 challenger?
« Reply #4 on: February 02, 2010 - 01:05:14 PM »
You could use the Federal. But the Saginaw is more correct design for the year car. Federals were last used in 71.
If there's a pick n pull near you, go there and see if there's any to get. Or try Craigslist, or here in parts wanted. They're a commonly used pump in many Mopars.
« Reply #5 on: February 02, 2010 - 01:09:25 PM »
Oh and the cap that doesn't fit?
Maybe a TRW.
They didn't have an over hang edge but fit within the filler top.
Offline dutch
« Reply #6 on: February 02, 2010 - 01:11:44 PM »
 :iagree:  I had a `81 van and I`m pretty sure it had a long neck like that .  no Idea what type it is though...
*** Bart ***
Offline challngd73
« Reply #7 on: February 02, 2010 - 01:12:11 PM »
thanks topcat for all your help.  one last question, will i need all new brackets if i switch to saginaw?
« Reply #8 on: February 02, 2010 - 01:17:03 PM »
It depends on what it comes off of. Bouchillion performance has all the brackets if you run into problems. Call them if you run into line up issues.
I think I would inquire here if I were you in parts wanted and just get everything from someone.
