In all of my searching on this forum, I found a thread where someone had posted a diagram of how to install the offset bushings.
It was a great diagram and now for the life of me I have NO IDEA where it was!
I found several references to "how to" but they were conflicting:
"To get the additional caster (street car 2.5 -3.0 degrees), the upper ball joint has to move toward the rear of the car. This is done by installing the offset bushings such that the ones closest to the front of the car push the control arm out and the ones to the rear pull the control arm in. These will offset each other and camber will not be affected."
and then
"There should be arrows on the bushing, just point them in the directions as shown. Arrows towards the outside of the car in the front and arrows inside towards the engine on the back."
Problem: The arrows on the bushings I got seem to indicate the opposite of what the second post says.
So I thought I would referto to the diagram...but cant find it!
Anyone know what I am yapping about?
