Author Topic: 440 Cooling Fan  (Read 1211 times)
Offline mojavered
  • Someday!
440 Cooling Fan
« on: February 03, 2010 - 08:53:51 AM »
I need to get a fan for my 440.  I do not want to go electric, and I want the best cooling fan I can get.  Is there a recommended fan?  I guess I need to measure my fan shroud to see what I can fit.  I was looking @ the Mopar Viscous Fan Package offered by Mancini.  Any and all recomendations are welcome.  Thanks!
« Last Edit: February 09, 2010 - 11:48:47 AM by mojavered »
Jason
Re: Need a Fan
« Reply #1 on: February 03, 2010 - 10:15:30 AM »
I use the Flex-A-Lite 18" universal 6 blade fan on a new clutch hub , they are not a flex fan & they do move a lot of air , the fans are cheap at around $50 , the hub will cost closer to $100
Re: Need a Fan
« Reply #2 on: February 03, 2010 - 05:22:50 PM »
Offline mojavered
  • Someday!
Re: Need a Fan
« Reply #3 on: February 03, 2010 - 09:27:01 PM »
How important is a fan clutch?  I have heard some say that they weight too much and that they always remove them.  Thanks for the recomendations!
Jason
Offline mojavered
  • Someday!
Re: 440 Cooling Fan
« Reply #4 on: February 09, 2010 - 11:53:20 AM »
So what do you think?  Anyone running a fan without a clutch?  Does it rob too much power?  Is it something that can be omitted?  Thanks.
Jason
Re: 440 Cooling Fan
« Reply #5 on: February 09, 2010 - 12:03:30 PM »
the clutch is the most effcient way to cool
Offline FJ5_440
  • Wisconsin
Re: 440 Cooling Fan
« Reply #6 on: February 09, 2010 - 01:35:57 PM »
I was having some cooling issues on my car, so i tried a fixed fan and spacer from Speedway motors.  It pulls more air than the new clutch fan setup did, and I mostly just cruise around, so I wasn't too concerned about losing a couple horsepower.
Fan - Fixed Blade Max Volume 910-1576-18    $34.99
Fan Spacer - 1.75"                  910-15720-175    $8.99
** Shane **
