Author Topic: 72-74 Rallye fender louvers...with all mounting pins intact  (Read 1307 times)
« on: February 03, 2010 - 11:39:12 AM »
I have two sets of the 72-74 Rallye fender louvers.  My origonals are missing most of the mounting pins.  I bought a set at the Nats 10+ years ago that are only missing 2 or so pins per side.  However the bodyshop really would like a pair that still has ALL of the pins intact and usable.  So let me know what you have...thanks...
Incase I can't find a good set, does anyone have a fix for these?  What have you done?
Offline coupman35
  • It going to be FUN
Re: 72-74 Rallye fender louvers...with all mounting pins intact
« Reply #1 on: February 03, 2010 - 04:09:55 PM »
I saw a set on kijiji they look good .You said you hade two set you dont have a set of spare insert for them.
Iltry to fin the add and post the link
1941 Dodge truck 340cu
1935 ford 3window coupe 327cu
1965 Acadian Beaumont Convertible 283cu
1973 Challenger 318cu
« Reply #2 on: February 03, 2010 - 04:20:54 PM »
I just have my origonal inserts...
Offline coupman35
Offline coupman35
« Reply #5 on: February 08, 2010 - 09:16:53 AM »
THat first one is a little out of my price range.  The second set looks to have a lot of pins missing.  Thanks for looking though.
« Reply #6 on: February 09, 2010 - 09:22:32 AM »
I recieved an e-mail from someone who has a pair of louvers.  We'll see if we can work out a deal.
« Last Edit: February 10, 2010 - 09:29:45 AM by burdar »
Offline coupman35
« Reply #7 on: February 09, 2010 - 12:51:07 PM »
If they are in good shape whit all the pin and plastic insert  id say it a good deal.
« Reply #8 on: February 09, 2010 - 12:56:52 PM »
I e-mailed him back asking for another pic with all of the mounting nuts removed to I could accually see the condition of all the pins.  We'll see if his is able/silling to send another picture.
« Last Edit: February 10, 2010 - 09:30:41 AM by burdar »
Offline coupman35
« Reply #9 on: February 09, 2010 - 01:11:51 PM »
There is a few on eb... just for one they wont like 75.00S.Plus just the insert sell for 100.00$ or bit less.Am looking for as set of insert hope to fin set at good price .
« Reply #10 on: February 10, 2010 - 09:31:00 AM »
Still looking...
« Reply #11 on: February 10, 2010 - 09:56:00 AM »
  :thinkerg:  Have you ever considered drilling out the broken studs & replacing them?
Probably would need to epoxy in some all thread.   Even if you had to drill all the way through & countersink something with a head then cover with filler....I could see it working.  :2cents:
« Reply #12 on: February 10, 2010 - 09:58:24 AM »
That's what we were going to do if we couldn't find some good ones.  The problem is that the area where the pins are missing is very very thin.  It is impossible to drill and tap threads in it.  Some epoxy would have to be used and I'm not sure if that area would start to crack in a couple years.
I'm sending you a PM
Offline Pistol Gripper
« Reply #13 on: February 11, 2010 - 10:08:03 AM »
Let me look when I get home and see if I have a set.  Probably have them, finding them ?  Another issue.
P.G.
O ne
B ig
A $$
M istake
A merica
« Reply #14 on: February 11, 2010 - 10:16:43 AM »
I think I just found a set.  I'll let you know if it doesn't work out.  Thanks
