rear seal is easy to change,,getting it out ,pry it out just be careful an slow,putting it back in just use a rubber mallet and keep it straight,once it starts tap evenly around the seal,,should tap in easily just take your time and dont hit to hard,,its not thick,1/4" or so at base,,something the same diameter of the outer seal can be used to tap it in,,such as a socket,,and with a deeper pan make sure you add enough fluid
