Author Topic: dana 60  (Read 1363 times)
Offline 70 rtse
dana 60
« on: February 05, 2010 - 06:19:55 AM »
would an a body dana fit a e body
Re: dana 60
« Reply #1 on: February 05, 2010 - 12:12:02 PM »
only if you relocated the spring inward a bunch
Offline 70 rtse
Re: dana 60
« Reply #2 on: February 07, 2010 - 12:41:01 AM »
thanks the one i was looking at sold how much would i have to pay for a good dana diff
Offline farmboy70
Re: dana 60
« Reply #3 on: February 07, 2010 - 08:52:02 AM »
The one in my car was 2600.00 delivered from Dr Diff. You can have one made from a truck donor for less but you have to do something about the lack of pinion mounting plate.
The good thing about the repop is it's all new and ready to bolt in :2thumbs:
Re: dana 60
« Reply #4 on: February 07, 2010 - 08:56:53 AM »
Doc dif  makes the snubber mounting plate kit for 60 bucks (58.00)  I installed it on my truck dana I built.  To narrow a 3/4 truck dana is 150 bucks, moser ends are 90.00, doc dif axles are around 300, the rest depends on the sure grip you have and gear selction. I paid 250 for a 35 spline powerlock.
Offline farmboy70
Re: dana 60
« Reply #5 on: February 07, 2010 - 09:01:11 AM »
I meant the machine work to mount the plate.
Re: dana 60
« Reply #6 on: February 07, 2010 - 09:07:21 AM »
there is no machine work to mount the plate with his kit. He taps 3   1/2 inch solid bars, angles the bottom of the bar stock for the propper fit to the center section, then you use a mig welder to weld the stands on. It took about 20 minutes was all on a rack with the dana installed. I put the bar stock on the snubber plate, then put the snubber plate on the dana in the right spot, put a tac on each bar stock, removed the snubber then finished the weld.  The snubber cost extra :2thumbs:
Offline moparmaniac59
  • Drive it like ya stole it!
Re: dana 60
« Reply #7 on: February 07, 2010 - 10:03:00 AM »
I wish I was near Cullman AL. I could sure learn a lot hanging around Al's garage!!! :bigsmile:
                                                 Matt B.
Matt
