E Body Clutch Pedals: Are they the same as B Body Pedals?
Author Topic: E Body Clutch Pedals: Are they the same as B Body Pedals?  (Read 3665 times)
Offline Road_Runner
« on: February 05, 2010 - 10:35:47 PM »
Are 70-74 E body clutch pedals the same as 68, 69, 70, 71-74 B body pedals?  I've got an extra B body set and it occurs to me that it might fit my 73 Barracuda.  I read Chryco Psycho's write-up on 4 speed conversions and it seems to imply that they might be same but it isn't totally clear.
Thanks, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: E Body Clutch Pedals: Are they the same as B Body Pedals?
« Reply #1 on: February 05, 2010 - 10:39:19 PM »
they will bolt in and are the same size however the shap of the clutch peddal arm and the pads are differant.
They will work just fine.  :working:
Go Fast & Have Fun...
Offline Road_Runner
« Reply #2 on: February 05, 2010 - 10:47:35 PM »
Interesting, is the arm different for a particular reason, to position it differently, etc. or is it just an aesthetic thing?  Can the pads be swapped to make it look correct?
Thanks for the info, Jim
    • THE DODGE BOYS
« Reply #3 on: February 06, 2010 - 06:22:46 AM »
aesthetic, maybe they are smaller and slanted, b bodys are more square ish
Offline quapman
    • Auto-Grip on Facebook
« Reply #4 on: February 06, 2010 - 06:30:14 AM »
71-4 B-body pedals are the same as E-body. The underdash brackets are different, but you can swap the good stuff over to your E-body brackets.
Offline Road_Runner
« Reply #5 on: February 06, 2010 - 09:10:43 AM »
May keep looking for the correct set of pedals, but its good to know I've got something that works.  Thanks.
Offline Road_Runner
« Reply #6 on: February 06, 2010 - 09:12:18 AM »
That's basically what I did with my Roadrunner, good to know that I can do the same with the Barracuda.
Thanks, Jim
Offline Aussie Challenger
« Reply #7 on: February 07, 2010 - 01:03:06 AM »
Check out Brewers site, I think they have pic's of the different pedals.
Offline 71chmark
« Reply #8 on: February 07, 2010 - 05:55:41 AM »
The B body pedals are bigger which may explain the arm difference.  Here is a picture of the B body pedals in mine. I saw them sjde by side. Got my conversion stuff from brewers. The B body pedals were 50 bucks cheaper.  Bolted right in no problem.
I may be schizophrenic,
Offline Road_Runner
« Reply #9 on: February 08, 2010 - 01:08:15 PM »
Thanks for the pics!  I'm saving them for reference.  I'm still waffling about long-term plans for my choice of transmissions.  Gathering the info here is invaluable allowing me to make up my mind with the most complete idea of the issues & options.  For the next year or two I'm definitely staying with the automatic, but the idea of having the pistol grip 4 speed (which I already have most of the pieces for) keeps tugging at me!!
Thanks again, Jim
Later, Jim
Offline femtnmax
« Reply #10 on: February 14, 2010 - 10:15:58 PM »
Be ready to spend more than you figure to switch over to 4 speed.  Cost of all the parts goes on and on.   Seems to get a good trany need to buy rebuilt from Brewers or such, or be ready to have to fix it first.  Still worth it for those wanting it.
Phil
