Author Topic: Fenders to body sealant  (Read 1863 times)
« on: February 06, 2010 - 09:41:31 PM »
I saw this stuff and it sounds like it may be the right type of stuff to use between the fender and the apron panel edge.
http://cgi.ebay.com/ebaymotors/SEM-39357-FLEXIBLE-URETHANE-FOAM-2-Component-AUTO-PAINT_W0QQcmdZViewItemQQhashZitem5acf2b6950QQitemZ390022785360QQptZMotorsQ5fAutomotiveQ5fTools
Anyone use it and does it replicate the foamy stuff in between like the factory used?
Offline Canadian Cuda
Re: Fenders to body sealant
« Reply #1 on: February 06, 2010 - 10:38:32 PM »
I used 3M strip caulk. dont think it's like factory. but did the job :dunno:
Geoff
70 Cuda 440-4, auto, 8 3/4 sure-grip
« Reply #2 on: February 06, 2010 - 10:50:51 PM »
When I first took off my fenders, there was a brown foamy stuff in between.
My theory is that the fenders need a more forgiving pliable material that is durable, waterproof, and doesn't peel off easily like silicone could. At high RPM's your front end is vibrating pretty hard. Too hard a cauling transfers vibrations into the front.
Offline elitecustombody
  • Supra collector
« Reply #3 on: February 07, 2010 - 12:24:27 AM »
Yes,expanding foam is the proper way to seal that area  :poopoke:
Stefan B
Offline farmboy70
« Reply #4 on: February 07, 2010 - 08:36:46 AM »
Be sure that you have good fittment on the fenders first, if you have to move the fenders for alignment it will get messy and not leave the area lokking good for paint.
Offline AZDAN
« Reply #5 on: February 10, 2010 - 12:15:39 AM »
Any product names or suggestions as what brand and where to find?
« Reply #6 on: February 10, 2010 - 01:23:37 AM »
The auto paint store I went to this week had one brand of foamy glue that sets up in 1 minute. I can't figure out how anyone can hang a fender on and have it done before it dries within that time frame.
Offline Kapteenikosmos
« Reply #7 on: February 10, 2010 - 01:51:20 AM »
Well this isn't the original way but I think that you could first install the fender and then seal it afterwards from the outside, inside the wheel well. This way the sealant wouldn't be between the fender and body, just on corner of the fender and body but it should prevent the moisture getting between gap.
I think that the main use for the sealing is to keep the water from the wheel well entering inside the engine bay?
 I haven't decided yet what stuff I'm going to use so I would also appreciate if someone has solid knowledge of stuff that holds there.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline Chlngrcrzy
« Reply #8 on: February 10, 2010 - 07:28:02 PM »
 :popcorn:
« Reply #9 on: February 10, 2010 - 08:01:22 PM »
I spoke with Tony (fishin4cuda) on the subject today.
He mentioned that the foamy stuff dries up really quick and doesn't give you much time to work with it. I suppose you could have everything rehearsed on panel alignment, using colored 3M tape on its final fit line up as guide point/areas. Then squirt it on top of apron edges and work really fast.
« Reply #10 on: February 10, 2010 - 08:23:39 PM »
I went to the paint n body supply place and they gave me some  type of 3m tar strips just for the fender sealing
« Reply #11 on: February 11, 2010 - 12:42:42 AM »
thats the 3m Strip caulk i used
http://www.amazon.com/3m-MS-8578-12-Strip-Calk-Pieces/dp/B000PEZ1L4
Geoff
