Author Topic: removing leaf springs  (Read 1363 times)
Offline barryv
« on: February 07, 2010 - 09:37:12 AM »
hi, can someone tell me  a good safe way to remove and install leaf springs,thanks in advance
Re: removing leaf springs
« Reply #1 on: February 07, 2010 - 11:33:07 AM »
Jack up the car place stands under the frame both sides & stands under the diff as well , remove the rear valance , remove the rear shackle , cut or unbolt the U bolts over the diff & undo the 4 bolts at the front of the leaf spring hanger & lower the spring
Offline barryv
« Reply #2 on: February 07, 2010 - 07:36:39 PM »
thank you
« Reply #3 on: February 07, 2010 - 10:55:30 PM »
 :2thumbs:
Offline challengermaniac
« Reply #4 on: February 08, 2010 - 01:56:49 AM »
If you have a rear sway bar, support it in place as well.  Most guys remove the rear valance, but I found it worked okay to leave it in place as long as you unbolt the front of the leaf springs first for removal and bolted up the rear first for reinstall.  Once you have eveything back together, be sure to only hand tighten the front and rear bolts until you have the weight bearing on them.
Charlie
70 Challenger
69 Camaro RS
« Last Edit: February 08, 2010 - 01:58:44 AM by challengermaniac »
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
