Seems like as a new guy here I'm full of questions!! Everyone here has been so helpful, I thought I'd give you guys another opportunity. The driver side bucket seat in my 73 Barracuda is bent or worn to the point where it reclines another 20-30 degrees than the passenger side does. I'm not sure if something is bent or if its something like the latch that is loose or worn to the point it allows it to rotate so much further backwards before the latch stops it. Has anyone had a similar issue with one or more of their buckets and can share what you did to fix it? Hopefully we're not talking about replacing the whole seat and there's a simpler (& cheaper) fix.
Thanks in advance, Jim
