Author Topic: 1971 Barracuda "PLYMOUTH" (the word Plymouth) emblem on nose near hood  (Read 1479 times)
Offline DocMel
Could someone post a pic of the PLYMOUTH (the word Plymouth) emblem located on a 1971 Barracuda on the nose, drivers side, near the front of the hood
Also, was this a standard emblem on all 71 Barracudas, or only if certian options were ordered?
Offline 360 'CUDA
Re: 1971 Barracuda "PLYMOUTH" (the word Plymouth) emblem on nose near hood
« Reply #1 on: February 08, 2010 - 11:45:13 PM »
All 'CUDAs and Barracudas have the same Plymouth emblem '71 to '74 on the front of the hood, drivers side. Only the 1970 hood is plain with no holes for the emblem pins there.  If you buy a hood with no holes is was off a '70 (Plymouth emblem was located on the Grille for 1970)
Sorry I don't have any pics at this time.  My hoods are in storage right now.
« Last Edit: February 08, 2010 - 11:53:08 PM by 360 »
Offline 360 'CUDA
« Reply #2 on: February 09, 2010 - 12:13:11 AM »
But then I remembered I have an old wrecked hood in the back so here are a couple of pics.
Not a good example but it gives you a reference to where the holes are. Obviously the P in Plymouth is hiding the third hole
Offline bentpshrods
  • Almost there, Boise Id.
« Reply #3 on: February 09, 2010 - 11:14:43 AM »
  Just finnished redoing the cuda 340 emblem with my model paints. Work canceled for the day and my project is to put these and the other hood pieces back on.
Offline DocMel
« Reply #4 on: February 09, 2010 - 01:12:29 PM »
Thanks fellas
« Reply #5 on: February 09, 2010 - 01:22:55 PM »
Are the holes for the emblems original or are you drilling new holes?
The reason I ask is because I recall seeing these on before (OEM) and they are not perfectly straight. Kind of slanted angle.
And now I think I know the reason why.
If you try to put them on perfectly straight, level; One of the pins will end up going right thru the brace on the underside. So when they put them on; they had them slanted so as not to interfere on mounting with the re enforcement brace on the inside of the hood.
If someone knows otherwise, please let me know.
Offline tommyg29
« Reply #6 on: February 09, 2010 - 05:51:24 PM »
heres what I can contribute
« Reply #7 on: February 09, 2010 - 09:05:57 PM »
That must be a 70 hood I believe.
71's had pre made holes for that emblem to sit flush underneath. They're different there on 71 up versus 70's.
Offline 2TAGS
« Reply #8 on: February 10, 2010 - 05:32:14 PM »
 :popcorn:
1971 'Cuda 340
Offline 1ownr
« Reply #9 on: February 10, 2010 - 05:58:13 PM »
here you go. Never been removed.
judy
« Reply #10 on: February 10, 2010 - 08:08:22 PM »
Judy
Do you have a pic on the underside? Also what type of nuts are holding it on?
Offline 1ownr
« Reply #11 on: February 10, 2010 - 10:37:08 PM »
underside, stamped tin nuts hold the emblem on.
judy
« Reply #12 on: February 10, 2010 - 11:56:05 PM »
 Thats what I needed to see. Thanks
