Author Topic: location to mount 70 cuda road lamp relay  (Read 10426 times)
Offline SCHU
« on: February 09, 2010 - 09:37:24 PM »
I need the factory location of where to mount 70 cuda road lamp relay, can anyone describe where the relay  mounting screw goes under the dash,  or does anyone have a pic ?  thanks  SCHU ,  dougandcindy@sympatico.ca`
Re: location to mount 70 cuda road lamp relay
« Reply #1 on: February 09, 2010 - 09:52:44 PM »
rally dash or standard dash?
Offline SCHU
« Reply #2 on: February 09, 2010 - 11:03:54 PM »
sorry I forgot,  I have a stock 70 rally dash & factory wire harness in my 70 cuda ,
thanks SCHU .
« Last Edit: February 09, 2010 - 11:06:09 PM by SCHU »
« Reply #3 on: February 10, 2010 - 01:45:02 AM »
you will see the mounting hole on the lower left side of your bottom steel dash. left of the steering wheel
Offline SCHU
« Reply #4 on: February 10, 2010 - 02:42:25 PM »
My Road lamp switch is already in the factory location for a 70 rally dash,  so using it as a reference how far away from the road lamp switch & in which direction is this relay mounting hole you are referring  ?
Offline swede-cuda
« Reply #5 on: February 11, 2010 - 03:17:13 PM »
 :clueless:i think moparal must have thought of the switch location on a rally dash? i have not mounted mine yet but as i remember learning from this site it should be next to the ash-tray,i hope someone puts up a pic of the exact location,as i also want to know for sure. :cooldancing:
Offline JayBee
« Reply #6 on: February 11, 2010 - 06:12:44 PM »
My  :2cents: . I've been watching this thread hoping for an answer too. From the Accessory wiring diagram for my 1970 Barracuda I can't for the life of me find anywhere where there's a relay. I'm pretty sure '71's had a realy but (according to the picture) I don't think '70 did. Am I wrong, is the schematic wrong or was there no relay in '70 models.  :dunno: .
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline 4 speed fish
« Reply #7 on: February 11, 2010 - 06:24:39 PM »
It goes by the ashtray.Your wire harness from the roadlamp switch will only go so far.The main wire harness will only let you connect it so far away from the relay.Connect the wires to relay from both harnesses and will give you a good location for the relay.It screws to the dash frame.THe 70 did have a relay.If you turn your high beams on the roadlamps will go off.
Offline SCHU
« Reply #8 on: February 11, 2010 - 07:18:39 PM »
Ok thanks, I will connect the harness like you suggest & then look near the ashtray to a hole for the relay where ever the harness allows.
 FYI `70 relay #2889916 has 3 terminals and it turns on the yellow running/parking lights when the road lamps are switched on,  while the 71 relay has an extra 4th terminal that allows the road lamps to be turned off by the high beam foot switch,  that is why both the 70 & 71 harness & road lamp switchs are different. Note the 70 Plymouth service manual does not show the relay it must have been missed by the editors.  thanks SHU.
Offline RB2929
« Reply #9 on: February 11, 2010 - 07:56:45 PM »
So, on a 71 cuda, if you want high beams and road lamps on at the same time, you should install the 1970 relay? :dunno:
Offline SCHU
« Reply #10 on: February 11, 2010 - 11:04:41 PM »
I can't answer your question for sure about swapping the relays without schematics of both wire harness & relays, because the harness wiring is different.
But a easier thing to try would be to simply disconnect the wire that comes from the dimmer switch(on the 71 relay it is the single terminal by itself, the other 3 terminals are clustered together), then turn the ignition key to the run position & try the high beam dimmer switch and look if the road lamps stay on ?  Make sure you cover/tape the wire terminal so it does not touch a ground.  Also with a factory relay & harness beware if you are running aftermarket high output headlights & road lamps with newer bulbs that may take extra current.
« Reply #11 on: February 12, 2010 - 03:42:36 PM »
Here's a pic of the 70 harness
Offline JayBee
« Reply #12 on: February 12, 2010 - 05:20:27 PM »
THANK YOU and THANK YOU. Looks like I'll be hunting for a harness and relay.
John
2014 Toyota Avalon
Offline dutch
« Reply #13 on: February 12, 2010 - 07:12:34 PM »
John, let me have a look tomorrow for ya...  my 70 came with roadlamps originally ,but the lamps were gone when I bought the car.  I do have the switch and I think I have the relais and harness as well.  I will use the switch, but I wont use the wiring. If I have what you need ,it`s yours.  :2thumbs:
*** Bart ***
Offline JayBee
« Reply #14 on: February 12, 2010 - 09:30:48 PM »
That's awesome Bart, I appreciate it. Thanks a bunch.  :2thumbs:
John
2014 Toyota Avalon
