Author Topic: how to install windshield propely  (Read 5111 times)
Offline barryv
« on: February 10, 2010 - 10:41:50 PM »
hi,can someone give me some advice as to how to install windshield propely  using the butyl tape as a sealant,thanks in advance
Offline 72cudamaan
Re: how to install windshield propely
« Reply #1 on: February 10, 2010 - 10:46:00 PM »
I thought urethane in a caulk gun was the way to go. Not positive on this application though
If I cant fix it, it's broke
Andy  (phukker whither)
Offline farmboy70
« Reply #2 on: February 10, 2010 - 10:51:13 PM »
The highlights would be make sure the channel is clean, prime with appropriate butl primer. Then roll out the butl tape near the edge of the window channel. I like to make the over lap in the tape on the side with the tape positioned so the water runs down and not trapping it. If it is a used glass make sure the glass is clean so you can see when the glass is pushed down you can see the seal.
Set the lower bumpers, lay the glass in carefully and checking side to side gap.
Press lightly and even all around outside.
Then seal outer edges with the proper sealer for butl. don't use urethane to seal this area.
One hint also be sure you have installed good window trim clips before you put the glass in.
Offline farmboy70
« Reply #3 on: February 10, 2010 - 10:56:52 PM »
You can install with urethane also but be sure to make some blocks to keep the glass from setting too deep in the channel.
The molding will look bad if the glass is too deep.
And again don't seal the edges with it as it will make installing the moldings a real pain.
If it drys the clips will be anchored,if the moldings are installed while it is wet they are now glued in permanently.
Offline 72cudamaan
« Reply #4 on: February 10, 2010 - 11:00:06 PM »
Ah, so thats why my windshield moulding was so difficult to remove. :faint:
Offline farmboy70
« Reply #5 on: February 10, 2010 - 11:05:18 PM »
Could be, but the factory/dealers filled the channel with caulking also. After 40 years they can be a bugger!
Offline 73EStroker
« Reply #6 on: February 11, 2010 - 11:11:53 AM »
Another tip is to use the etching compound, available from most glass or autobody supply store, on the window surround. Makes the sealer stick and seal better especially on clearcoat paints.
Barry (Salmon Arm)
Offline barryv
« Reply #7 on: February 11, 2010 - 09:33:37 PM »
thanks for the replies, the window channel is presently painted with por-15.do i still need some type of primer before i lay butyl tape.thanks
Offline farmboy70
« Reply #8 on: February 11, 2010 - 09:40:49 PM »
I would ruff up the POR a little. 180 grit should do it and then use the primer.
Offline barryv
« Reply #9 on: February 11, 2010 - 10:00:27 PM »
were would i get butyl primer,thanks
Offline farmboy70
« Reply #10 on: February 11, 2010 - 10:43:00 PM »
Most any auto parts store that handles paint should have it.
Offline dutch
« Reply #11 on: February 12, 2010 - 03:59:19 AM »
what determines the hight of the glass?
*** Bart ***
Offline farmboy70
« Reply #12 on: February 12, 2010 - 08:46:52 AM »
The thickness of the butl strip, I use 5/16 or 3/8 also.
If you use urethane I make small blocks to hold the glass up to the correct height. The urethane is very soft and the glass can settle too deep in the channel leaving a gap around the molding.
Offline UKcuda
  • Tell them I'm on my way
« Reply #13 on: February 12, 2010 - 03:13:46 PM »
I can testify to the importance of checking the installed height before you go in with the sticky stuff - my DIY screen fit left a huge gap between the glass and the trim and I had to use shorty trim clips for a '67 Dart (I think) to get it looking anything like.
There's still a gap there but no one seems to notice so I'm living with it
'72 'cuda
