Author Topic: 727 and Drive Line  (Read 910 times)
Offline mojavered
  • Someday!
727 and Drive Line
« on: February 11, 2010 - 10:14:49 AM »
I went to put my drive shaft in the other day.  I started looking inside the yoke and noticed that there was an area where the teeth had a larger gtoove between the teeth.  So, I looked at my tail shaft (already in the car) and noticed that all the teeth are the same distance apart.  I looked at another tail shaft on another 727 and noticed the same thing.  2 Quetions:
1:  I have not measured my drive line to make sure it is the correct shaft, but do the yokes usually have a large groove set in the teeth?
2:  If there is no groove in the tail shaft, does this mean that the yoke can go on any which way?
Thanks.
Jason
Offline mojavered
  • Someday!
Re: 727 and Drive Line
« Reply #1 on: February 12, 2010 - 11:11:53 AM »
Is there any information that I can give someone that would help?  Thanks.
Jason
Offline 72cudamaan
« Reply #2 on: February 12, 2010 - 08:57:00 PM »
That's a master spline. If you look closely at the output shaft you will probably see two splines that actually meet in a taper at the end of the shaft. This is where you would line up your master spline.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Aussie Challenger
« Reply #3 on: February 14, 2010 - 03:27:25 AM »
 I think that is a carry over from the old ball & trunion which used to be bolted onto the back of the out put shaft.
 Tactransman may chime in with the answer if my comment is not correct.   :bigsmile:
Offline mojavered
  • Someday!
« Reply #4 on: February 14, 2010 - 06:09:58 PM »
Thanks, I will look at the output shaft a little closer and see if I can see the taper.
Jason
« Reply #5 on: February 14, 2010 - 06:29:40 PM »
there is no master spline , the yolk is missing 1 tooth for oil supply
Offline mojavered
  • Someday!
« Reply #6 on: February 15, 2010 - 03:51:16 PM »
Thanks!  SO it does not matter where that missing tooth goes?
Jason
Offline tactransman
« Reply #7 on: February 15, 2010 - 05:25:13 PM »
Nope
Terry-tactransman
Union, Mo.
Offline mojavered
  • Someday!
« Reply #8 on: February 15, 2010 - 08:45:44 PM »
Right On :thumbsup:
Jason
