Well I flowed a few sets of my heads but I am more concerned with velocity & swirl for street engines than massive flow #, i do not open the heads up much but I remove restictions to flow , narrow valve guides raise the roof of the ports & leave the floors alone , I widen by the pushrod of course . I would have to dig up a flow sheet but I THINK I hit 270 on the intake side & 230 exhaust but I could be off , I do install the larger 1.81 exhaust valves as it increases the short side turn & promotes flow .
I live in a cold climate & have no issue starting these cars in even cool weather , just pump it a couple of times nurse the throttle for a minute or so & you are good to go , if you never see snow you will not have an issue
Thanks Neil, I know you aim at getting big #'s and in doing so look at every little aspect to achieve this and in doing so, you are one of the best with our MoPar engines. However, in your honest opinion, for my situation, do you really think it's worth porting the heads? What hp gains could I see from a good cam change, the Dominator, 850 and unrestricted air cleaner set up?
Any more input on the cam?
Not sure where to go on that, the 528 MoPar still looks nice. For me, I guess I want a pretty decent change, I would hate to do this work put it all together then find the differences are just about unnoticeable. If I could I'd like to lean towards the performance side more than the "mild", if that makes sense lol.
Thanks guys!
