Well I have never done that swap , the roll pin is not bad to remove , hammer & punch , hit it hard a couple of times & it will slide out , I use a pickle fork to get the coupler to slide off the slines if it is tight , the rest Should be a bolt in , I assume you have some kind odf adapter to plug in the Turn signal switch as they use a gm switch to my knowledge
