Author Topic: Shock selection help  (Read 2450 times)
Offline djwhog
« on: February 13, 2010 - 12:17:39 AM »
OK I was wondering for better handling, not track or drag racing what is a good shock to use on an a 70 cuda E body?
I need better handling and still want decent ride, but firm is OK.
Was looking at these...http://www.summitracing.com/parts/EDL-33840/
Edelbrock Performer IAS Monotube Shocks (seems these are stiffer)  :ylsuper:
and
Edelbrock Classic IAS Shocks
anyone use these and can detail the diff in the 2 lines for me?
thanks!
__________________
 :drama:
Dyno Dave
Re: Shock selection help
« Reply #1 on: February 13, 2010 - 10:43:45 AM »
They are the same thing. The only difference is the color, Performers are red, classics are gray.
I've got no personal experience with Ebrock shocks, but I've heard good feedback on them for street applications. Track use may be another story as they tend to fade with sustained aggressive driving.
Yes, mono-tube shocks may tend to feel a bit more firm than a comparable twin tube. This is because a mono-tube has more oil to move and as a result may have a higher resistance to motion. This also means that they have bigger discs internally are more sensitive to changes in velocity in their travel and can exert greater control over wheel motion. By contrast a twin tube is displacing less fluid and may feel smoother in its motion. Because it is a tube within a tube, they can still be function if the bod is damaged, where a mono tube will be junk.
Offline shadango
« Reply #2 on: February 13, 2010 - 11:20:43 AM »
I ended up getting KYBs......
Inexpensive and they claim some performance gain.
Havent tried them yet though.
« Reply #3 on: February 13, 2010 - 11:54:21 AM »
I bought and installed the classic Edel IAS. There was a huge improvement in handling on the rough city streets. I replaced about 15yr old monroes so I think ANY shock would have been an improvement though. :bigsmile:
Offline shadango
« Reply #4 on: February 13, 2010 - 12:49:51 PM »
LOL The shocks on my car were REALY REALY old...........made this funky squishy noise as you move them.....no resistance (barely) at all....so I agree, anything in my case will be better!
Funny thing though...the car rode "ok"........ :dunno:
Offline Carlwalski
« Reply #5 on: February 13, 2010 - 01:12:24 PM »
I have the classic IAS shocks installed and love the ride. Nice and firm but smooth as hell, especially on the highway. When I push down on the rear end of the trunk to see how low the trunk goes, it's around 1-1/2" to 2" (max) with a good firm push, nice and tight. ;)
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 73EStroker
« Reply #6 on: February 13, 2010 - 02:26:10 PM »
I have the Edlebrock red ones. The car handles bumpy corners and still stays on track. Some stiff cheap shocks will bounce you sideways in that situation. Of course you pay more to get more or vice versa.
Barry (Salmon Arm)
Offline djwhog
« Reply #7 on: February 14, 2010 - 09:05:31 AM »
Thanks guys for the feedback,
I was also looking at Koni's but they are more than 2 times the price and not sure how much better if any they would be.
I am leaning towards the performace Vs the classic Edelbrock mono's, I want to get better handling if they are the next notch up.
Offline drewcrane
« Reply #8 on: February 14, 2010 - 09:27:00 AM »
if you are willing to spend the money it is worth it to go a good pair of adjustable shocks,QA1 makes an affordable adj. shock, look in to them if you have the money  :popcorn:
« Reply #9 on: February 14, 2010 - 06:28:46 PM »
There is no difference between the two Edelbrocks, one is red, one is gray, that's all.
 Yes, there is a noticeable enough difference between a Koni and an E-brock for the price. Koni's are a world class shock with engineering and construction to back them up. They will be the last shocks you ever buy because if you don't like the valving or if you ever think you wore them out, you send them back and they fix them. It is kind of the difference between buying a Rolex or buying a Fossil.
Offline 500Stroker
« Reply #10 on: February 14, 2010 - 07:57:04 PM »
Got rid of KYB's and went with the Eddies years ago.  Huge improvement in ride quality and handling
Offline djwhog
« Reply #11 on: February 15, 2010 - 09:26:20 AM »
Thanks so much all, yep I had KYB fair not great, I just need to determine I guess if I am willing to spend the $$s for the Konis, but I think the eddies would be way better than what I have now.
Offline Roppa440
« Reply #12 on: February 16, 2010 - 11:34:09 AM »
I have used KYBs for many years and always thought they were OK for the money. And money has been very tight.
But while in the US I got to drive my buddys Challenger fitted with stock 383 suspension and QA1 adjustable shocks.
Put it this way. My KYBs are comming OFF asap and the QA1 shocks are on on their way from Summit.
Another mate of mine has just made the same swap on his B-body and he reports it is like driving a different car. They make a huge difference.
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
« Reply #13 on: February 16, 2010 - 02:47:44 PM »
IMO, shocks are to the suspension what a camshaft is to the engine. They determine the whole operating range, feel, performance, and manners of the whole system.
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« Reply #14 on: February 16, 2010 - 07:04:22 PM »
I have gone from stock what ever shocks to KYB, Koni and now this spring I will get to play with a set of XVs and a set of Bilsteins from Firm Feel..
I cant wait to see what happens.
Jackson from Toronto.
