Author Topic: 727 or 904 - shifter madness - I don't have any hair left to pull - HELP!!!  (Read 13267 times)
Offline az-nick
    • NicksClassicParts
Re: 727 or 904 - shifter madness - I don't have any hair left to pull - HELP!!!
« Reply #30 on: February 14, 2010 - 12:56:31 PM »
Nick I think maybe you have the wrong shifter arm on there. I ran into a similiar issue , I had a B&M shifter arm on when I bought my car ( see first picture) I changed my car from a column shift to a floor shift. The second pic is the arm I used. No there is not a bushing on there!
Hey Brad - I am confused, how can you tell by looking at the pics I posted that the bracket is wrong, not trying to be sarcastis, just trying to learn and understand, thanks again!!
Offline az-nick
    • NicksClassicParts
« Reply #31 on: February 14, 2010 - 01:00:02 PM »
Sorry for the last post, I didn't realize there were additional posts added before I posted, sorry again....
I am going under the car again and look at the front arm in question... Be back in a few....  :thumbsup:
« Last Edit: February 14, 2010 - 01:21:46 PM by az-nick »
Offline az-nick
    • NicksClassicParts
« Reply #32 on: February 14, 2010 - 01:38:02 PM »
Got under there and took this pic.
Yes the bracket looks like the L shape backet.
No the horizintal rod does not look like it hits the neutral safety switch, with the car in Park there is enough room for me to slip my hand flat between the rod and the switch.
Look at the pick, the arrows show 2 things, the one looks like a bracket and the other is a square boss, they were connected together but not tight, I was able to lift the bracket off the boss, I am sure this is the down shift arm from the carb, am I correct or not?
The bracket has a round hole and the boss is square.... something is not right!!!
Offline az-nick
    • NicksClassicParts
« Reply #33 on: February 14, 2010 - 01:45:43 PM »
Brad - Yes the car was original with a console setup but the problem lies when the owner decided to put a 360 into this car when it was originally a 440 equiped car from the factory.
Steve - By the looks of the underside of the car and K frame and other attributes, I can almost safely say that this is really an original 15,500 mile car and not a mile more. He has been putting this motor and trans combo in this and has taken his sweet time..... The trans is dirty because it has a bad pan leak and the underside of the car is also undercoated, this is sweet, I am shocked.....
« Reply #34 on: February 14, 2010 - 02:06:26 PM »
Nick, looks like you have the wrong prnd2l lever, yours should be straight. Send me your address and I will send you one out. It is a straight one
Offline az-nick
    • NicksClassicParts
« Reply #35 on: February 14, 2010 - 02:11:27 PM »
Thanks AL, I will PM it to you!
Offline az-nick
    • NicksClassicParts
« Reply #36 on: February 14, 2010 - 02:21:49 PM »
Next question I have is....(Sorry for the depth of this post but I need to figue out what is wrong and correct it)
Anyone have a picture of what the Nuetral saftey switch looks like when it is installed and with the wires attached, I am noticing that mine looks not correct and before I start to take thing apart I need to see it correctly! Thanks
Offline quapman
    • Auto-Grip on Facebook
« Reply #37 on: February 14, 2010 - 04:19:24 PM »
Yep, as we suspected, wrong lever. It was too cold out today to see if mine is straight or "L" shaped. I've got a 70K mile 318/904 slap-stik setup.
Judging from the molded-in plastic bushing in your lever, it's from something in the late 70's-80's with a snap-in type linkage.
NSS is a hex-shaped doohickey with three brass prongs sticking out from it. A molded plastic connector with a 3-wire harness clips onto it and goes to the bulkhead connection under (above?) the windshield wiper plug.
« Reply #38 on: February 14, 2010 - 10:28:53 PM »
Hi Nick :wave: The arm that you have off in your picture is the kickdown lever,It looks exactly the same as mine! if you look it has a "half moon" hole that fits the tranny shaft. Just make sure it goes through both holes before you try to tighten it.
« Reply #39 on: February 14, 2010 - 10:31:31 PM »
Hey Al he needs the spring that goes under the console too? I looked in the stuff you sent me but I don't have an extra. If you don't understand what I meen , look at the picture he posted?
Offline tactransman
« Reply #40 on: February 15, 2010 - 10:52:25 AM »
Yup,like everyone has said,the upper bushing is bad because it's missing the four tabs to hold it in place.
The shifter lever is wrong and very loose hole fit where the rod slips in.
Terry-tactransman
Union, Mo.
Offline az-nick
    • NicksClassicParts
« Reply #41 on: February 15, 2010 - 05:05:25 PM »
Steve - you are correct, the trans is a 76-79 year, it came with the motor, so said the last owner.
NSS looks different and I am not sure if it is because of the later year trans or if he has added to the covering or something, in one of the previous pictures you can see a tie-strap in the NSS vacinity and I do not know what it is doing or why it is there. Also it looks like there is a wire from it going towards the friver door and it is also wrapped up in electrical tape.
I will have to investigate and take more pics.....
Offline az-nick
    • NicksClassicParts
« Reply #42 on: February 15, 2010 - 05:07:06 PM »
Thanks I will look at it closely when I have the car up on stands and then I can fit under it....  :bigshades:
Offline az-nick
    • NicksClassicParts
« Reply #43 on: February 15, 2010 - 05:08:24 PM »
He Al, I hope you have these, let me know if you dont and I will start an internet search for them.... thanks
Offline az-nick
    • NicksClassicParts
« Reply #44 on: February 15, 2010 - 05:12:24 PM »
Must be a late model version lever, thanks for the input Terry, question, will the dealer have the correct pan gasket for these and what should I order from them, should I just say it is for an A body 727 or did the 360 use a B body 727? I have never owned a small block like this, sorry....
