Author Topic: What color epoxy primer should I use?  (Read 12109 times)
Offline Challenga
  • All I ask is the chance to prove that money can't make me happy......
« on: February 13, 2010 - 02:51:52 PM »
I am just about to go and buy some Omni epoxy primer to start priming my car before doing the little bit of body filling I need to do.  I was planning on buying the gray, but I was thinking about getting the black because it would be easier to see imperfections, it would seem.  Does anyone have any thoughts on this?
FYI - I am painting it Go Mango in the end.
Ben
1970 - Challenger A66 - Go-man-go!
sleepychallenger
Re: What color epoxy primer should I use?
« Reply #1 on: February 13, 2010 - 03:28:23 PM »
i just bought the black. havent used it but my buddy says that it makes it a little easier to see the imperfections.
Offline Challenga
« Reply #2 on: February 13, 2010 - 04:21:03 PM »
Good, I am glad someone else recommended it.
Offline Cuda Cody
  • Vancouver, WA
« Reply #3 on: February 13, 2010 - 09:34:07 PM »
Assuming you're starting with bare metal, get red.  PPG DP74.
Epoxy and guide coats are different and you want them to be different colors to make it easier to see.  With a Go Mango color use Red epoxy and a black guide coat.  You'll be sanding most of the guide coat off and that will be easy to see.
« Last Edit: February 13, 2010 - 09:38:15 PM by C O D Y »
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #4 on: February 14, 2010 - 06:43:13 AM »
I prefer gray or yellow primers and use a black guide coat but it is more personal preference I guess.On my road runner I am going with gray and leaving the underside in primer with only overspray for the factory look.Primer color can affect the final color somewhat also.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline LAA66
« Reply #5 on: February 14, 2010 - 11:02:46 AM »
 By using a similar color primer to final paint, it can help hide the inevitable paint chips that occur. Especially behind the wheel wells.
« Reply #6 on: February 14, 2010 - 11:10:42 AM »
I found this recently and thinking to use it.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270514469699&ssPageName=STRK:MEWAX:IT
Question:
What types of primers are compatible with what types of paints?
It says urethane. Is that a 2 stage or a single only?
Offline RUSTY Cuda
  • One big step foward!
« Reply #7 on: February 14, 2010 - 11:24:05 AM »
Not a pro here but I've been told if your using it as a metal sealer you are going with high build over it so you want to see when you hit it so as not to sand it all off, so a different color from your high build should be used. Rich.
Offline Cuda Cody
  • Vancouver, WA
« Reply #8 on: February 14, 2010 - 11:36:26 AM »
Exactly.  :2thumbs:
Offline Challenga
« Reply #9 on: February 14, 2010 - 07:15:11 PM »
How does this sound for a plan guys?  When I have it in the paint booth, I put down two coats of yellow or red epoxy primer, then shoot some different color high build primer, and then one thin coat of black on top as a guide coat?  Do you think that would be a good combo?  I would be doing it all in the matter of 3 days or so.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #10 on: February 14, 2010 - 08:56:18 PM »
waste of material imo  :2cents:
epoxy is your first coat and will be coated many times after. Black has a higher zinc content,  if your going with  an orange color then your sealer is more important before painting.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline elitecustombody
  • Supra collector
« Reply #11 on: February 15, 2010 - 12:02:57 AM »
^ yep :iagree:
Stefan B
Offline Challenga
« Reply #12 on: February 15, 2010 - 03:05:41 PM »
Dave Stefan - you guys think I should put on black epoxy, high build primer, then some yellow or red sealer?  What i am getting from everyone is the fact that the layers I put on should all be different colors so that I can "see" where I am at when I sand or build up.
One question though - Dave, you mentioned "zinc content".  Does the zinc make it bond to the bare metal better?
« Last Edit: February 15, 2010 - 03:15:36 PM by Challenga »
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #13 on: February 15, 2010 - 07:04:41 PM »
epoxy the car what ever color you want to use, then put on a high build primer, a little guide coating NOT a full coating as that would be a waste of material, block the car smooth to what ever grit you want or upto 400. If you break through on a high spot reprimer and block until flat. sealer is the first coat BEFORE painting, other wise if you use the sealer now you will have to rescuff and reseal before painting. the sealer you can tint with base coat to aid in better coverage of the base coat.
ZINC is the key to metal prepping, either a zinc wash as in metal ready or ospho, this neutralizes the metal so moisture doesnt penetrate the steel and start rusting again. Black has a higher zinc content vs, grey, red, yellow. at least in the RM/BASF line that I know of.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
  • Supra collector
« Reply #14 on: February 15, 2010 - 08:48:35 PM »
Keep in mind, most epoxy primers can be converted into sealer by just adding more reducer in the mix, but if you want red ,you'd better off just buying 2 quarts of tintable sealer.
I've been using Sherwin Williams epoxies and just love the way they cover ,lay down and flow out,amazing adhesion and it sands fairly easy too
Stefan B
