Author Topic: Broken door locks  (Read 709 times)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
Broken door locks
« on: February 14, 2010 - 06:09:56 AM »
So I go to lock my Challenger the other day and the key will not go into the lock.  It appears that one of the tumbelrs has fallen off inside.  Also I cannot lock the car fom the inside.   Can this be fixed without re keying the whole car?  Can a locksmith do this?
Re: Broken door locks
« Reply #1 on: February 14, 2010 - 01:39:53 PM »
if the first cut on the key near the head of the key is shallow the short pin will eventually turn sideways in the lock as it wears preventing the key from going in unless you use the tip of the to pull the pin back a little . basically you nned to replace the lock itself , a new lock can be pinned to match your existing key , keeping the locks lubed with graphite will help prevent this happening
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #2 on: February 14, 2010 - 08:03:54 PM »
I think that is what is happening Cryco..  The tip of the key gets in about 1/8" then is stopped.
I will get a new lock and have it matched to my key.   Thanks!
