Author Topic: ignition problems  (Read 6122 times)
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
Re: ignition problems
« Reply #30 on: March 09, 2010 - 02:17:35 PM »
We have it running, it was the condenser. The auto part store said they didn't think you needed a condenser with an electronic ignition control. This is it: do we need one?
That little SOB caused me SO MUCH trouble back in my day.   :pullinghair: I went though all the same trouble that you just experience but the car was my daily driver.  I hate them damn things even though I know what their deal is now.
If I could have remembered, I would have chimed in.  :banghead:
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Offline shadango
« Reply #31 on: April 11, 2010 - 11:37:35 AM »
that is what the book says altho I have seen other sources that suggest a bit more.  I have found that some systems may not generate a spark at significantly wider gaps when cranked-particularly if the battery is not fully charged.  The same ones would generate a spark when I connected a spare distributor and spun the shaft.
All my feeler gauges have a .011 brass blade so I set it tight with one of those.
When setting the gap on the pickup, I am finding that I can slightly affect the gap as I turn the shaft a bit....in other words the shaft moves ever so slightly :sideways".....the distributor is a reman and very few miles on it....so I think its fine.  But how do you set an accurate gap with that scenario?
Offline UKcuda
  • Tell them I'm on my way
« Reply #32 on: April 11, 2010 - 04:41:49 PM »
just get it as thin as you can without anything touching
'72 'cuda
Offline shadango
« Reply #33 on: April 11, 2010 - 07:56:51 PM »
Gotcha.
I think I have it set right.  I used .010 feeler but I think its more like  .011 or .012.  The factory manual specifies that you can force the feller to fit and that is NOT the way to do it...so it is to be a loose fit.
I think I have it OK.
Guess I'll find out when I get my harness back.  Fingers crossed. LOL
« Reply #34 on: April 11, 2010 - 10:48:30 PM »
I set it at .008 minimum
Offline shadango
« Reply #35 on: April 11, 2010 - 11:04:00 PM »
Yeah, I saw your post saying that in another thread....I saw others were saying they go wider, up to .016.  Then others at .12 or so....LOL
The book says .008......but I am not sure I have 100% faith in my feeler-ing skills     :bigsmile:    so I figured better to go a tad wider and avoid a crash on startup....
Any chance pickups can act funky with heat...ie cut in and out during "run" but work fine during "crank" ?  I figured not, but figured I would throw that out there....
« Reply #36 on: April 11, 2010 - 11:04:54 PM »
Yes I have found a few pickups that quit as they warm up
Offline shadango
« Reply #37 on: April 11, 2010 - 11:22:48 PM »
But they quit working altogether, right? In other words, no spark when cranking.
« Reply #38 on: April 12, 2010 - 01:13:35 AM »
Yeah the engine shuts down & will not restart
Offline JoltinJoe
« Reply #39 on: April 12, 2010 - 01:16:51 AM »
Shut down and drove me mad 20 years ago!
Offline shadango
« Reply #40 on: April 12, 2010 - 04:45:31 AM »
Ok....thats why I dont think thats my issue here....it shuts down, but I have spark while cranking...just wont run.
I have  spare on its way anyways from rock auto.....as a backup.  But that'll be my next thing to replace ( replaced the ballast and ecu, and the harness is being gone over).
