Author Topic: Slapstik removal - cleaning with what and then lubricate with what?  (Read 1169 times)
Offline az-nick
    • NicksClassicParts
I would like to remove and clean my Slapstik shifter assembly while I have the chance, how and what do you recommend I should do to it? What cleaning agent did you use and once finished, what did you use to lubricate it with, I have both White Lithium and Gray grease?
« Last Edit: February 15, 2010 - 09:30:44 PM by az-nick »
Re: Slapstik removal - cleaning with what and then lubricate with what?
« Reply #1 on: February 15, 2010 - 09:26:06 PM »
white lithium
Offline az-nick
    • NicksClassicParts
« Reply #2 on: February 15, 2010 - 09:35:03 PM »
Neil - Thanks, any ideas on which solvent to use and shoud it be a spray or try to soak?
I just want to remove the carpet fuzz and varnish that has resided in the mechanism?
« Reply #3 on: February 15, 2010 - 09:38:04 PM »
Carb cleaner , brake clean ,varsol if you have a tank ,all will work
Offline az-nick
    • NicksClassicParts
« Reply #4 on: February 15, 2010 - 09:44:32 PM »
thank you....
Offline BIGSHCLUNK
« Reply #5 on: February 15, 2010 - 10:31:07 PM »
Nick, I used brake cleaner.... no residue! And second the white lithium!  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #6 on: February 16, 2010 - 08:06:47 PM »
Blow it out real good with compressed air. They get a lot of lint/fuzz & trash being where they are. I think mine had a few Mcdonald's french fries down in there along with some pocket change! :smilielol: :roflsmiley: :smilielol:
                                                   Matt B.
Matt
