Author Topic: Frame connectors?  (Read 5599 times)
Offline 67vertman
  • Member since 9-23-2005
Frame connectors?
« on: February 15, 2010 - 10:52:40 PM »
Thanks everyone.
Offline BIGSHCLUNK
Re: Frame connectors?
« Reply #1 on: February 15, 2010 - 10:57:35 PM »
I already had the boxes , making the connecters was $10 in materials.....  :working:
« Last Edit: February 15, 2010 - 11:14:19 PM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #2 on: February 15, 2010 - 11:00:50 PM »
All 4 Torque boxes and frame connectors. And if your going Dana, there's a re inforcement plate to add on while you're at it.
Offline 67vertman
« Reply #3 on: February 15, 2010 - 11:09:10 PM »
Thanks Mike and Bigs.
Mike, yes I am planning on a Dana as well.  :2thumbs:
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #4 on: February 15, 2010 - 11:13:12 PM »
I'm going to be installing home made subframe connectors and possibly home made torque boxes if I have time this weekend.
1996 Dodge Viper GTS Coupe
« Reply #5 on: February 15, 2010 - 11:30:22 PM »
Offline 67vertman
« Reply #6 on: February 16, 2010 - 12:10:37 AM »
Thanks Mike.
Did you also add the rear spring supports as well?
I ordered my 1" torsion bars from Just Suspensions tonight.
« Reply #7 on: February 16, 2010 - 01:58:22 AM »
Thanks Mike.
Oh you mean the re-inforcement plates for the leaf springs front bracket mounts?
Yes those are on also.
« Reply #8 on: February 16, 2010 - 08:32:35 AM »
Its easy enough to do both, why not, but at least do one or the other if the budget is tight.
Offline cudazappa
« Reply #9 on: February 16, 2010 - 09:38:20 AM »
You'll see the most gain with subframe connectors.  The torque boxes add a little.  If combined, they equal 100%, the SFCs will be about 85% (guesstimate) of the package.
2015 Dart GT - Daily Driver
Offline 67vertman
« Reply #10 on: February 16, 2010 - 01:53:05 PM »
Is there an advantage to the weld in connectors compared to the bolt in ones?
It seam to me that welding them in gives support to the body pans as well as supporting connecting the frames.  As the bolt in ones only tie the frames together.
Offline 426HEMI
« Reply #11 on: February 16, 2010 - 02:00:33 PM »
weilding in makes the body tighter and more strudy.   :2cents:  That is what I am going to do on mine also.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline 67vertman
« Reply #12 on: February 16, 2010 - 02:06:45 PM »
Yep, that's what I ment..... :banghead:
It looks like I have lots of welding to do in my future.... :jumping:
« Reply #13 on: February 16, 2010 - 08:06:08 PM »
I used two pieces of 2x3 box tubing and slit the floors and welded them full length. The only drawback is the carpet has a lump behind both front seats. I don't spend any time back there so it doesn't bother me though :bigsmile:
Offline SBDave
« Reply #14 on: June 08, 2010 - 02:38:44 PM »
Hey dodj!
Any pictures of the 2x3 install?  It sounds like you did it how I want to.
Thanks!
