Author Topic: calling tactransman - 727 suggestions  (Read 658 times)
Offline UKcuda
  • Tell them I'm on my way
« on: February 16, 2010 - 05:12:09 AM »
Hi Terry,
I read your excellent rebuild/upgrade thread but I only have a little experience with transmissions and I'm not sure how far I really want/need to go.
I want to upgrade a 727 to go behind a 360 Magnum which I will be swapping into the 'cuda later in the year.  The engine is 10:1 CR with a lively cam so should be quite revvy.  Rear is 3.23 suregrip.
The 727 I am looking at using was originally behind an early magnum 318; I believe 1993.  I haven't used it and I don't know what vehicle it's from but there's no sign of anything wrong with it.
I plan to use the original convertor which came with this trans. and which is 10 and a bit inches (I know about balancing the flex plate).
This car is for regular street use and will only see the odd run down the strip.
So I know you are going to say put a Transgo kit in it - should I just leave it at that? and is there anything I should check for on this transmission before I get started?
Cheers
Steve
'72 'cuda
Offline UKcuda
Re: calling tactransman - 727 suggestions
« Reply #1 on: February 16, 2010 - 07:04:16 AM »
Anyone else is welcome to post as well of course
'72 'cuda
Offline tactransman
« Reply #2 on: February 16, 2010 - 09:23:16 AM »
Hi Steve..........  :wave:  If it is a '93 I would make sure it is NOT a lock up style.
I do not know if you have seen this thread or not but there is a bunch of good info here:
http://www.cuda-challenger.com/cc/index.php?topic=20391.0
Terry-tactransman
Union, Mo.
Offline UKcuda
« Reply #3 on: February 16, 2010 - 12:28:49 PM »
Yeah, that's the thread I was talking about, I thought it was excellent.
I'm just not sure how far I ought to go beyond just fitting the shift kit as my car is for regular street use.
I think I already decided it's not a lock up - I can't remember why I decided that, it was a while ago - I'll need to double-check my thinking there.
Thanks
'72 'cuda
Offline tactransman
« Reply #4 on: February 16, 2010 - 01:12:44 PM »
Put the Transgo kit in it with the mods in the Archive thread.
Change the rear servo with a Sonnax billet one.(the stock cast one likes to crack)
http://www.sonnax.com/part_summary.php?id=3496&pl=3
Make sure you have a 3.8 ratio lever for 2nd gear.
Terry-tactransman
Union, Mo.
Offline UKcuda
« Reply #5 on: February 16, 2010 - 01:43:51 PM »
OK thanks for clarifying - I wasn't sure if some of it was like "race only" or something.
'72 'cuda
