Author Topic: anyone used jegs direct fit or BeCool direct fit aluminum radiators?  (Read 2462 times)
Offline 70burntorangeT/A
Just wondering if anyone has used these in a 22in core support and how well they fit?
66 f-100 black  240 straight 6  3 on the tree.....currently blown up :(
70 challenger burnt orange 440 727 3:23-weekend cruizer
Offline IMNCARN82
  • LeDZeP
Re: anyone used jegs direct fit or BeCool direct fit aluminum radiators?
« Reply #1 on: February 21, 2010 - 08:41:01 PM »
I have a BC rad. in the small opening. It fits perfect. Not sure if it's the same one though.It did a BIG difference in cooling. Also JEGS 12x2 fans.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #2 on: February 24, 2010 - 03:21:43 AM »
I have the 1000 hp be cool rad kit from summit racing comes complete with fans and all i love it and it fits well but cost some cash about 1200.00
michele
Offline Roppa440
« Reply #3 on: February 24, 2010 - 08:13:27 AM »
I fitted a "bolt in" BC radiator to my Challenger's 26" opening and had to modify the mounting flanges dramatically as it would not fit between the frame rails. Even then it would not sit low enough to cool correctly in the airflow from the grille so I had to cut it some more to get it lower.
But it just took some work with the angle grinder and I had to drill new holes to bolt it to the stock radiator frame.
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
« Reply #4 on: February 25, 2010 - 08:58:51 PM »
Is that the cheap one or expensive one? the one im looking at is 299, for a std. transmission as i am running an external tranny cooler. It is also a cross flow. I cant find a downflow that is under 700 or so.
Offline IMNCARN82
  • LeDZeP
« Reply #5 on: February 25, 2010 - 11:53:35 PM »
It's an expensive one. Like 6 hundy. Worth it.  Crossflows are supposed to cool better.But I had fitment issues with the RMS K. (Lower hose). It was one of the few I could find that did not have the lower outlet right on the corner. I had a Jegs direct fit for like 299,had to return it.But only because of the outlet/K issue.Otherwise it fit good. Hope this helps.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #6 on: February 25, 2010 - 11:58:32 PM »
the BeCool crossflow i looked at didnt have the inlet/outlet on the corneres so i may try one before i spend 600..worst thing i have to do is send it back
Offline Got JOB
  • Member since 2-14-06
« Reply #7 on: March 01, 2010 - 04:55:48 PM »
Pic of my BeCool crossflow
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
« Reply #8 on: March 01, 2010 - 06:02:41 PM »
I just picked up a Day Motorsports triple pass, cross flow unit for $200. Haven't fit it up yet, but it will require fabbing new upper and lower mounts. I think it was 29"x 19" x 3".
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #9 on: March 01, 2010 - 08:34:07 PM »
I am using a Smith Racing Radiator direct fit, 26", fab aluminum. You actually loose surface area on a cross-flow due to each end cap that covers a portion of the radiator opening. The Smith radiator was about $600 bucks. It made a big difference.
                                               Matt B.
Matt
« Reply #10 on: March 01, 2010 - 08:38:59 PM »
                                               Matt B.
i may loose a little surface are but considering that the original cores are 9/16th of an inch and the alum rad cores are 1 inch it will still make a pretty big difference.
