Author Topic: Need help! Bad grinding noise from starter?  (Read 652 times)
Offline Doomed
  • So close...to actually finishing my 'Cuda!
« on: February 21, 2010 - 10:01:04 AM »
I'm finally getting real close to getting my 'Cuda up and running, but I came into another problem - of course.
I turned over the engine yesterday and I heard a loud grinding noise. It sounds like its coming from from the starter when its engaging.
I'm running a 440 with a Powermaster XS Torque mini starter and a Keisler 5 speed. Do I have the correct starter? Or is it something else?
Kyle.
"Life gets in the way of Living"
Offline Changin Gears
Re: Need help! Bad grinding noise from starter?
« Reply #1 on: February 21, 2010 - 02:29:47 PM »
Does that stater have the 1" alignment "guide" that pilots into the bellhousing?
Offline Doomed
« Reply #2 on: February 21, 2010 - 04:59:54 PM »
I'm not sure, what does it look like? It bolted right on, I did'nt see anything else but the starter in the box.
Kyle.
« Reply #3 on: February 21, 2010 - 05:50:52 PM »
It's a 1" diameter snout that goes into a pilot hole inside the bellhousing that sets the sets the distance from the flywheel to the starter.  The factory starters all have them.
