Author Topic: 1970 to 1971 Cuda ;Auto Shift Handle questions  (Read 962 times)
Offline DocMel
« on: February 21, 2010 - 07:00:55 PM »
I have a 71 Cuda with a 1970 style slap stik shifter handle/ball.
Im looking at getting back to the 1971 correct  T Handle shifter
Questions:
The center console.  Its a 70.  DO I need to change out center console form a 70 to a 71?
SHifter mechanism:  Do all I need to do is change out the shifter from a 70 back to a 71, or does the entire shift linkage from the shifter, all the way to the tranny have to be changed?
Im hoping all I need to do is change out the shifter assembly from the ball to the T style assembly
Alaskan_TA
Re: 1970 to 1971 Cuda ;Auto Shift Handle questions
« Reply #1 on: February 21, 2010 - 07:14:47 PM »
The ball & T-handle interchange, no need to do anything else.
Offline DocMel
« Reply #2 on: February 21, 2010 - 08:15:24 PM »
So all I need to do is remove the ball, replace with the T handle?
Alaskan_TA
« Reply #3 on: February 21, 2010 - 08:30:28 PM »
Yes.
« Reply #4 on: February 22, 2010 - 11:41:42 AM »
you need to swap out the entire shifter assy as the shaft is round for the ball & rectangle for the T handle but nothing else needs to be changed
Offline hotrod98
    • Maniac Musclecars
« Reply #5 on: February 23, 2010 - 10:13:33 PM »
The slider in the bezel is different as well. The 70 has a round hole and the 71 has a rectangular hole.  The consoles will interchange.
Note...The 70 console is worth about twice as much as a 71 up console.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
