Author Topic: Manual Tranny for Hemi  (Read 2242 times)
Offline Mopar_Mudder
  • I'm a llama!
« on: February 22, 2010 - 01:19:25 PM »
Trying to decide on the best route to go for a manual tranny in a 71 Hemi Cuda. Don't need the tranny right now but I have to decide to figure on the gear ratio so I can get the rear end done.
It would be nice to go with an overdrive but does it get really expensive trying to put something like a T56 in?
Looked at the Passon A833 overdrive but I don't really like the idea of a 3spd with overdrive, just seams like a step backwards to me.
So is it just best to stick with a stock A833, which I would have to find.......
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Re: Manual Tranny for Hemi
« Reply #1 on: February 22, 2010 - 01:42:55 PM »
well you have 3 options , the Tremec 5 spd od , the Keisler 18 spline hemi OD or the factory 833 OD , the keisler & the factory are basically a bolt in deal , the tremec is a bunch of modifing & it is really no where near as strong as the 833 version .the other consideation is the gearvendor that bolts onto the rear of the 833 4 spd , it is probably the strongest way to go & will give you 5 speeds
  • I'm a llama!
« Reply #2 on: February 22, 2010 - 02:14:30 PM »
Seeing as I don't want a 3spd with OD and I think that the cost of getting a Tremec to fit really isn't worth the benifit, I think I will just stick with a stock 4spd.
1971 Hemi Cuda
Offline 73EStroker
« Reply #3 on: February 22, 2010 - 02:27:13 PM »
MM- there was a standard 4 speed made way back that had the 3:09 first gear with 1:1 4th. But I don't think it was a hemi spline - I believe it was 23 spline only. That would give you the option to run a slightly taller rear without sacrificing takeoff.
Barry (Salmon Arm)
« Reply #4 on: February 22, 2010 - 05:49:03 PM »
all 833 trans have a 1 to 1 fourth gear, unless you get an overdrive with the 309 first
  • I'm a llama!
« Reply #5 on: February 22, 2010 - 05:59:01 PM »
I was refering to the Passon kit that converts you 4 speed 833 to a 3 speed with over drive. Standard 4 speed with a 1:1 4th is the best option. Only way I will do overdrive is a 5 or 6 speed but that sounds costly.
1971 Hemi Cuda
Offline bigblue73
« Reply #6 on: February 23, 2010 - 01:21:44 PM »
To obtain the 5 or 6 speed you have these options.
The Tremec TKO's are a very stout piece that, as mentioned above, is modified to fit in the chassis.  The T56 is a whole new bag of worms.  The T56 Magnum is a large and long transmission.  The cost for the extra gear is $600.00 over the price of TKO 5 Speed.  The modifications to make a six-speed fix into the E-Body platform include cutting / removal of the existing tunnel, cutting / removal / rebuilding of the torsion bar cross member - that's all.  I have a cross member for the T56 Magnums for the E-Bodies that is one items that would not have to be created.  If your interested in the T-56 Magnum swap - I'll post what it takes in terms of parts and hardware when I get to my home computer.
Tony Edler
Hurst Driveline Conversions
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #7 on: February 23, 2010 - 01:29:39 PM »
Tony Edler
I think that would be great information to be shared. There has been a lot of debate on the T56 install on these cars.
1996 Dodge Viper GTS Coupe
Offline 73EStroker
« Reply #8 on: February 23, 2010 - 02:32:02 PM »
The standard A833 I was referring to was the A body unit and it does have a 3.09 first gear and 1:1 4th. No good for E body though unless you do some big changes. Also 23 spline only. Check out the History section from Brewers.
Barry (Salmon Arm)
« Reply #9 on: February 23, 2010 - 02:48:21 PM »
How much HP/Torque are you planning on? A 23 spline can take alot. If you ever plan on slicks, I can see the necessity for a 18 spline even more then.
Here's a read:
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5696444&an=&page=&vc=1
