Proportioning valve question- wilwood adjustable versus "combination valves"
Author Topic: Proportioning valve question- wilwood adjustable versus "combination valves"  (Read 37070 times)
Offline shadango
Re: Proportioning valve question- wilwood adjustable versus "combination valves"
« Reply #15 on: February 24, 2010 - 05:11:45 PM »
Cool.  Well, It should be like night and day...I am switching from drums in the front to disks...installing this in same process....
Where did you start yours out as far as the initial setting...full open?
« Reply #16 on: February 24, 2010 - 06:13:31 PM »
To tell you the truth, I don't remember. But I do remember going out driving and nailing the brakes hard. I kept restricting the rear brakes until they stopped locking up. Haven't touched it since. :2thumbs:
Offline Changin Gears
« Reply #17 on: February 24, 2010 - 06:17:18 PM »
The ones I have done ended up being all the way in (full restriction).
« Reply #18 on: February 24, 2010 - 06:27:13 PM »
All my brake stuff is original equipment from 1970 as far as I can tell. Flex likes etc... My car was converted to the 73-74 spindles and disc breaks before I bought it. I have never driven my car yet. That being said I'm replacing my flex lines( Russell braided lines),wheel cylinders,and calipers, when I replace the master with the Dr.Diff unit. I'm liking the wildwood one that Bullitt posted!( Thanks Wade!  :wave: ) I have a brand new Wilwood single in/out adjuster from a past project . Money aside( it's not thats expencive) which way should I go? I'm just thinking I should replace everything from the original 40 year old system in the name of safety? With the investment I have in the car now what's another $60 I'm thinking? Any opinions on that out there?
« Reply #19 on: February 24, 2010 - 07:44:22 PM »
If you're replacing everything, you can go with the dot5 fluid shadango was talking about. From what shadango said it doesn't eat paint, thats gotta be a plus.
« Reply #20 on: February 24, 2010 - 07:45:37 PM »
Ya Neil (CP) said that too
Offline shadango
« Reply #21 on: February 24, 2010 - 07:48:48 PM »
ARe you replacing all your steel lines too? If not they need flushed to use the Dot 5.
Me, I am keeping mine as they are in great shape......not sure if they are original or what but they look real good.
See my other post about DOT 5....I read a lot of negative stuff about it......I figure Dot 3/4 have been around forever and works well aside from the eating paint thing....
(Coincidentally....I thought brake fluid would help diossolve the old undecoating caked on my k-member splash shields?  Huh....not even close.)
« Last Edit: February 25, 2010 - 09:11:42 AM by shadango »
« Reply #22 on: February 24, 2010 - 07:54:26 PM »
No not replacing my steel lines . They are in like new shape!! I'll flush them out and blow them out too.  Just trying to decide what p-valve to use?
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #23 on: February 24, 2010 - 09:27:43 PM »
Any one running or have any experience with a line lock for locking up the front brakes?
Go Fast & Have Fun...
« Reply #24 on: February 24, 2010 - 09:32:13 PM »
Well, if the prop valve you have works, I'd say use the valve and adjuster you have. If you have reason to be suspicious of your present prop valve, go with the one Bullitt posted. :2cents:
By the way Brads70, are there any decent chrome shops down there at that end of the province?
« Reply #25 on: February 24, 2010 - 10:50:31 PM »
I have no idea how/if the p-valve works or not? I haven't driven the car before? If its for a drum/drum car shouldn't I change it? I guess for the sake of $60 I should change it?  :dunno:
Sorry I don't know of any chrome shops?  None in Barrie, I'd guess maybe in Toronto?
Offline IMNCARN82
  • LeDZeP
« Reply #26 on: February 24, 2010 - 11:24:28 PM »
FWIW my disc/drum prop valve doesn't look quite like that. Might want to replace yours with a disc/drum unit? Not that I know the difference. Plus the new one will be NEW! Shiny brass.I need to re-do my M/C,factory prop. valve. :icon16:  Oh... And I'd like to know about the front line lock too... :popcorn:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline shadango
« Reply #27 on: February 25, 2010 - 01:58:09 AM »
From what I understand, we drum/drum people have distribution blocks, not proportion valves, stock -- and we dont need the stock style valve if we are going with an aftermarket unit in the rear line like a Wilwood.  :2cents:
Offline shadango
« Reply #28 on: February 25, 2010 - 02:06:19 AM »
:popcorn: we are both in the same boat with the same parts at the same stage! LOL
This is what I have now on the car ,can anyone ID it as a drum p-valve or a disc-drum p -valve? Sorry don't mean to hijack your post , just thought seeing as we are in the same boat sharing info would help us both? :2thumbs:
Just referred to the factory manual to double check.....according to it, and going by your picture, we both have a simple brake warning switch....it is not a metering or proportioning valve.
« Reply #29 on: February 25, 2010 - 09:01:57 AM »
Hummm I was told that drum or disc brakes need residual pressure to keep something seated,just can't remember which? :dunno: :clueless:
