Carpet "accessories"
Author Topic: Carpet "accessories"  (Read 1740 times)
Offline burnt orange
« on: February 26, 2010 - 11:52:57 AM »
Does anyone supply carpets with the metal grommet and the white plastic seatbelt thingies?
Offline sprecks
Re: Carpet "accessories"
« Reply #1 on: February 26, 2010 - 01:32:06 PM »
I've never seen an after market carpet with the seat belt thingies. Uou're probably going to have to reuse your old ones if you can.
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
« Reply #2 on: February 28, 2010 - 12:10:22 PM »
OK, thanks sprecks.
I can reuse them.
Any info on the grommets?  Do after-market carpets come with grommets? .........Anyone?
Offline whitesatinmopar
  • Member Since 3/30/02
« Reply #3 on: February 28, 2010 - 01:06:27 PM »
Don't know where you bought your carpet, but the 4 replacement carpets I've bought from Legendary across the years have also had a color matched grommet (plastic) for around the dimmer switch. And I have also bought replacement seatbelt "sleeves" from them. You probably can however find mental brass gromments at a hardware store to fit,?
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline Katfish
  • 70 Challenger
« Reply #4 on: February 28, 2010 - 02:18:42 PM »
I just finished carpet install on my car, bought it from ACC.  They are supposed to be 1 of the best suppliers.  Didn't come with any brass grommets.  I didn't see any of those on the carpet I took out either.  Where are they, what do they do / hold?
Here's some info
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=QuestionAnswer&Number=5644227&fpart=1&PHPSESSID=
Alaskan_TA
« Reply #5 on: February 28, 2010 - 05:16:58 PM »
The dimmer grommets are not OE, the factory just cut a hole in the carpet.
There are tabs under the rear seat, the grommets slipped over those, then the tabs were bent to the rear to secure the carpet edge under the rear seat.
« Reply #6 on: February 28, 2010 - 05:42:48 PM »
Yeah, the ones I am asking about are the ones in the carpet at the back seat corners that go over the tabs.  Are they in replacement carpets?
Alaskan_TA
« Reply #7 on: February 28, 2010 - 06:52:27 PM »
Not that I have seen so far.
« Reply #8 on: March 01, 2010 - 07:49:17 AM »
Sorry, I guess I should also look at the detail pics closer when I read  :clueless:  But in my defense sence there were no babes in this car related thread I glossed over ther pics.  :roflsmiley:  No, none of the carpet replacement projects that I have done included those. I just carefully cut a hole for the anchor bolt and used a flat washer to secure the carpet around the bolt, then slid the seat belt "sleave" back down over the bolt head.
Sorry I didn't pay close enough attention to the pic you showed and I posted a dimwit reply, but the plastic one around the dimmer switch was included.
1970 Charger 500
1971 Dart Swinger
1973 Challenger
Offline Katfish
  • 70 Challenger
« Reply #9 on: March 01, 2010 - 06:19:11 PM »
I'm really slow, anyone have a pic of these grommets and where they go under the seat.
Offline swede-cuda
« Reply #10 on: March 02, 2010 - 05:40:34 PM »
 :wave:yes,where are these mental brass grommets located?are they being strapt down,tied up,locked down,are they being hold down with straps spotwelded to the floor? or are they being heavily medicated with strong downers? :cooldancing: :bigsmile:
« Reply #11 on: March 02, 2010 - 09:24:24 PM »
Those mental brass grommets just hang around in the back corners of the carpets behind the plastic side panels.  They don't fasten to anything as far as I can tell! :dunno: :clueless:
Offline Katfish
  • 70 Challenger
« Reply #12 on: March 03, 2010 - 06:51:09 AM »
Ok now this just doesn't make sense.  You must be a really hardcore originality type of guy?  You want to get grommets for repo carpet, that no one reproduces and don't actually hook to anything?
J/K you a little, but you must be missing a tab or something?
« Reply #13 on: March 03, 2010 - 01:07:49 PM »
Yeah, and when all the interior parts are reinstalled you can't see it either!! :roflsmiley: :roflsmiley:
No tabs or anything that I can see.
If you could see my "restoration" skills you would never think me hardcore! :roflsmiley: :roflsmiley:
I'm just curious I guess?
Offline Katfish
  • 70 Challenger
« Reply #14 on: March 03, 2010 - 05:54:09 PM »
I could see where those would help.  My rear carpet could actually use a couple grommet/tabs near the tranny hump in the rear to hold the carpet down.
I learned something, this is my 2nd Challenger and neither 1 had those on the carpet.
Thx!
