Author Topic: 727 - Are they all the same?  (Read 1879 times)
Offline CUDA JAS
  • vroooooom!
« on: February 26, 2010 - 09:29:33 PM »
I am thinking of switching out my lock up 727 trans in my Cuda (more TQ converter choices).
I am thinking of picking up one from a junkyard, likely out of a truck or van (that is all there really is around here) and rebuild it.  Is there any thing that I need to watchout for, different, bad gear sets etc.
Thanks,
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline 70burntorangeT/A
Re: 727 - Are they all the same?
« Reply #1 on: February 26, 2010 - 11:47:19 PM »
the trucks and vans will have a different tailshaft. I bought one out of a motor home and the case was different, then i had a guy put the internals out of the motor home in a car housing, the motorhome trannys had extra clutches and bands or something like that and i believe some of the heavy duty truck trannys did too, supposed to be much stronger.
66 f-100 black  240 straight 6  3 on the tree.....currently blown up :(
70 challenger burnt orange 440 727 3:23-weekend cruizer
« Reply #2 on: February 28, 2010 - 12:43:55 PM »
there were constant changes , part throttle kickdown was added as well as different valve bodys & NSS switches , as well as different amounts of clutches in the clutch packs for HD applications
Offline tactransman
« Reply #3 on: March 01, 2010 - 09:46:41 AM »
A 2WD truck or van one will be fine as long as it looks like the regular version and does not have the short shaft/bolt on yoke style.The two "tab" hole bosses on the bottom of the extension housing are necessary for the "slap stick" console. Stay '68 and newer also.
Terry-tactransman
Union, Mo.
Offline acudanut
« Reply #4 on: March 01, 2010 - 10:32:31 AM »
 WRONG ^^^ above. the Truck Transmission 2wd or even a 4x4 will not work. I have made this mistake before. The mounting tabs are not there for your car. The internals are the same.  THAT'S it.
Offline tactransman
« Reply #5 on: March 01, 2010 - 10:57:34 AM »
Dude,it could have the tabs there,you can't say ALL truck transmissions won't work!!! That is why I pointed out to check and see if they are there. Chillax!
Terry-tactransman
Union, Mo.
Offline acudanut
« Reply #6 on: March 01, 2010 - 05:05:38 PM »
  I believe you are right. You sell these for a living.  I appologize, for I have not seen them all.  You sound like you know your stuff.
It's just that in my limited past experiece it's not just the mounting that won't work, it's the shorter tail issue. Every truck transmission I have played with did not have a slip in drive shaft, They had a yoke similiar to a rear end of a rear axle.
« Last Edit: March 01, 2010 - 05:11:01 PM by acudanut »
Offline tactransman
« Reply #7 on: March 01, 2010 - 05:42:00 PM »
I can tell you that when it comes to 2WD 727 truck transmissions,it is HARDER to find a bolt on yoke style than a slip in style. The bolt on yoke style is usually in a 4X4 with a divorced transfer case or a club cab long bed.  :cheers:
Terry-tactransman
Union, Mo.
Offline acudanut
« Reply #8 on: March 01, 2010 - 07:26:34 PM »
 Yea, and those are the ones I have dealt with. :cheers:
BTW I have a completely rebuilt BB 727 with a yoke on the end for a truck FOR sale. 300 Takes it. KC area
« Last Edit: March 01, 2010 - 07:30:13 PM by acudanut »
Offline CUDA JAS
  • vroooooom!
« Reply #9 on: March 01, 2010 - 08:59:58 PM »
Thanks guys...now I know what to look for.
If I can not find the right one, can I mix and match parts from the two...like if the tail shaft is wrong, can I use the tail shaft from the lock up on the non lock up???
Jason
74 'cuda 360/727
Offline IndyCuda
« Reply #10 on: March 01, 2010 - 09:30:06 PM »
He said Chillax!      :stirpot:
 :roflsmiley:
 :popcorn:
Offline CUDA JAS
  • vroooooom!
« Reply #11 on: March 01, 2010 - 09:35:08 PM »
 :roflsmiley:
 :popcorn:
Hehehe, yeah I saw that.....Dude, do you have a young daughter...Mine loves Hannah Montana, that is the only place I have heard that word!!!
74 'cuda 360/727
Offline IndyCuda
« Reply #12 on: March 01, 2010 - 10:40:28 PM »
Not that I know of...      :cooldancing:
 :roflsmiley:
 :ylsuper:
Offline tactransman
« Reply #13 on: March 02, 2010 - 08:50:07 AM »
Jason
YES
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #14 on: March 02, 2010 - 08:50:58 AM »
Yup,10 years old and LOVES Hannah Montana!!!!!  :smilielol:
Terry-tactransman
Union, Mo.
