Trying to get an idea what it takes and what it would cost to convert a 23 spline into an 18 spline. Re-conditioned one's go anywhere from $1,200 to 2K or more.
Perhaps it would be more cost effective to DIY conversion?
Any good upgrades to do while apart?
Passon sell the Hemi overdrive conversion.
http://www.passonperformance.com/images/stories/passon_documents/Passon_Overdrive_Flyer_20091109.pdfHas anyone done this? Does it include everything to do a 18 spline conversion?
So far I see the cluster gear, the main shaft, the input shaft all need to be changed out. Bearing retainer too it appears.
Also, new pressure plate, clutch, and throw out bearing. It looks like there's quite a few parts inside that are shared by both.
Here is the list to copy, then add so far what is all needed:
Cluster gear
Main shaft
Frt. Bearing retainer
Main shaft
Input shaft
Pressure plate
Clutch
Throw out bearing
