Author Topic: To Replace or Not To Replace (spindles, strut rods, TB's, and sway bars)  (Read 570 times)
Offline Cuda 72
I started work on the brakes/suspension. The wheel spindles seem to have some light ridges... is this normal?
Also, what's your opinion- should I replace the strut rods, TB's, and sway bars? I think they're all serviceable. Just looking to make her a daily driver again.
Re: To Replace or Not To Replace (spindles, strut rods, TB's, and sway bars)
« Reply #1 on: February 28, 2010 - 04:54:32 PM »
the spindles are fine
 the rest really doesn't need to be replaced unless they are bent or damaged or you want to upgrade to better parts
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« Reply #2 on: February 28, 2010 - 04:57:25 PM »
Replace all your old bushings and worn joints, set the alignment and hit the road.
If you want to turn faster then thats another story.
Jackson from Toronto.
Offline Cuda 72
« Reply #3 on: February 28, 2010 - 09:26:37 PM »
Thanks for the assist! With any luck, I'll have her on the road in April...
