Author Topic: Starter Suggestions for my 440-6pack Cuda w/ Headers  (Read 7900 times)
Re: Starter Suggestions for my 440-6pack Cuda w/ Headers
« Reply #15 on: March 08, 2010 - 02:03:50 AM »
I was able to use a Summit mini with Hedmans, but it touches the nose of the starter on one of the tubes. This is on a 383. Isn't a 440 wider?
 Yes the 440 is taller & wider moving the headers away from the starter slightly but not enough on the hedmans
Offline longgone
« Reply #16 on: March 12, 2010 - 09:11:28 PM »
Got the mini-starter on today.  I ended up getting one at a local o'reillys for about $100 new but it has a lifetime warranty.  Install wasn't bad.  I've got hooker headers so there was lots of room.  Car spins over very fast now.  Thanks everyone for all the help!
-Blueglow
Offline longgone
« Reply #17 on: March 14, 2010 - 09:59:10 AM »
So after driving the cuda around two days now with the new mini-starter on it.  I've realized this is a "MUST" for any mopar.  I didn't know how bad it was until this.  Perfect starts with no hesitation.  I'm loving it.
-Blueglow
Offline mojavered
  • Someday!
« Reply #18 on: March 14, 2010 - 11:20:18 AM »
blueglow, glad to hear it is working like a champ!  What year and vehicle did you tell them it was for?
Jason
Offline longgone
« Reply #19 on: March 14, 2010 - 11:29:20 AM »
95 Dodge pickup with a 360.  A new one was about $95 with a $5 core.  A reman was $59 with a $45 core... go figure.
I found out these starters fit about 40 different V8 mopars in that time frame.
Blueglow
Offline mojavered
  • Someday!
« Reply #20 on: March 22, 2010 - 04:51:15 PM »
Thanks blueglow.  I ended up getting part # 17181.  Is that the same one you got?  Did you have to grind off any of the inside edge of the flange on the starter to make it go in?  Mine seems a little tight and crooked.  Thanks!
Jason
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #21 on: March 26, 2010 - 09:21:34 PM »
well not sure what to tell you guys but the HEADMANS DO fit with the mini starters, i used these on our cuda 440+6 4 spd at work we built is that way, My wife 440 auto road runner has also, fit with NO clearance issues.
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #22 on: March 26, 2010 - 09:31:52 PM »
this is the engine we set up for the cuda at work. 440+6 4 speed, mopar nip mini starter with HEADMAN headers.
dont touch the starter or gear.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline mojavered
  • Someday!
« Reply #23 on: March 26, 2010 - 09:35:43 PM »
Mopardave, Can you please take a pic directly straight on from the front of that motor (and post)?  Thanks!
Jason
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #24 on: March 26, 2010 - 09:37:52 PM »
 well this engine is in the car. I'll log on to my work pc and see if I have and srtaight on pics of the engine.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #25 on: March 26, 2010 - 09:54:09 PM »
this is the best pic straight on i have
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline Road_Runner
« Reply #26 on: March 26, 2010 - 09:54:48 PM »
I was installing the headers on a 383 Roadrunner and as others have said here the taller deck of the 440 probably gives the starter a bit more room, but for me it wasn't even close.  I would have had to majorly dent the hedmans to make them work with the Mopar Performance mini starter and the Hooker 1 3/4" Comp headers I replaced them with worked fine.  I will say this was probably 15 years ago and Hedman could very well have made some changes since then.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline mojavered
  • Someday!
« Reply #27 on: March 26, 2010 - 09:57:52 PM »
Thanks Dave.
Jason
« Reply #28 on: April 01, 2010 - 01:42:41 PM »
Hedman may have changed the design but in my experience you will have to virtually dent the pipe to the point of closing  off the one pipe by the starter to fit hedmans on a big block with the mini
Offline longgone
« Reply #29 on: April 10, 2010 - 08:33:54 AM »
I've got Hooker headers on my 440 and the mini-starter went on with no problems.
Blueglow
