Author Topic: Fuel Vapor Canister  (Read 5270 times)
Offline ghjedi
Fuel Vapor Canister
« on: March 01, 2010 - 08:11:08 PM »
Hello,
My 1972 Challenger manual talks about a fuel vapor canister and mentions that the charcol filter should be replaced every so often.  Unfortunately, there is no picture of it nor is there a description of it.
Where could it be hiding?
1 of 1 1972 Challenger 440 4sp Convertible Blue GB2
2012 Challenger R/T Classic Blue Streak Pearlcoat
Offline farmboy70
Re: Fuel Vapor Canister
« Reply #1 on: March 01, 2010 - 08:22:53 PM »
On my 73 it was on the rad support on the passenger side.
Bad picture but you can see the fittings just over the support.
Usually they have been removed .
Offline ghjedi
« Reply #2 on: March 02, 2010 - 01:43:28 PM »
Thanks Farmboy70 for the response and photos!  I suspected it might be in rear by the gas tank, so thanks for setting me straight.
« Reply #3 on: March 02, 2010 - 02:52:37 PM »
The charcole canister can be seen in the above pics.  It is right in the front passengers corner where the radiator support and the inner fender meet.
The fuel vapor separator is located back by the gas tank.  It mounts to the shock X-member.  Here is a pic...
Offline ghjedi
« Reply #4 on: March 02, 2010 - 03:44:04 PM »
Thanks burdar.  I know for a fact that I don't have the charcoal canister in the engine bay, but I'll need to check for the vapor separator.  I don't recall seeing it, but then again, I've not taken a hard look at the underneath.
Offline IMNCARN82
  • LeDZeP
« Reply #5 on: March 03, 2010 - 09:23:46 PM »
Hey,Where did you get that vapor separator?    :popcorn:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #6 on: March 03, 2010 - 10:09:58 PM »
Me?  It's my origonal one.  I soaked it in EvapoRust and then had my father-in-law braze up a couple pinholes.  I then filled in most of the pits and painted it with Eastwoods "Tank Tone" paint...finally a coat of matte clear.
Here's what I started with...
Offline Doomed
  • So close...to actually finishing my 'Cuda!
« Reply #7 on: March 04, 2010 - 08:23:48 AM »
Do you actually need this? Is there a way to safely omitt the vapour separator?
Kyle.
"Life gets in the way of Living"
« Reply #8 on: March 04, 2010 - 08:48:19 AM »
A lot of people remove the charcole canister in the engine compartment but you still need to retain the separator.  It lets air into the tank as the gas is used up.
I guess you could drill a vent hole into the fill pipe somewhere that would vent the tank.  There is no reason to remove the separator...it weighes vertually nothing.  Just remove the canister in the engine comp if you want to but keep the vent line.
Offline IMNCARN82
  • LeDZeP
« Reply #9 on: March 04, 2010 - 09:17:00 AM »
Mine was toast. Couldn't find a new one. It kept leaking if I just plugged the holes. Had to drill a small hole in the cap to breathe. Even with the breather. That looks great!
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline Supercuda
« Reply #10 on: March 04, 2010 - 09:49:45 AM »
The filter that the FSM referred to, is a fiber or foam pad that is in the bottom of the canister, and the bottom is supposed to twist off so it can be changed. The canister is a win-win situation, as it traps evaporated fuel for you to use on your next startup, and doesn't steal any horsepower. Also, as mentioned, it weighs very little.
Offline Doomed
« Reply #11 on: March 04, 2010 - 10:13:48 PM »
Sweet, lots of good info.
Kyle.
