New 5.7 Hemi Stroker 370 CI
Author Topic: New 5.7 Hemi Stroker 370 CI  (Read 821 times)
Offline Dukes69
    • Pro Touring Mopar
« on: March 02, 2010 - 07:09:14 PM »
5.7 based 370 cubic inch stroker short block, 0 miles – Custom ground crank, Carrillo rods, ARP rod bolts, custom CP pistons (8.5:1 CR with 5.7 heads or 10:1 CR with 6.1 heads), Tool Steel Pins, balanced and assembled, Degreed Comp XFI260 cam, new timing chain set.  Full gasket set included.  No Core, asking $4000.
Thank you
-Chris
951-551-6181
chris@protouringmopar.com
Offline Dukes69
    • Pro Touring Mopar
Re: New 5.7 Hemi Stroker 370 CI
« Reply #1 on: March 03, 2010 - 09:22:03 PM »
I will split shipping with anyone in the lower 48.
Thanks
-Chris
Offline Dukes69
    • Pro Touring Mopar
« Reply #2 on: March 07, 2010 - 03:44:17 PM »
BTT
Maybe some perspective helps. New you can get this for $5000 + core charge ($400). I have no core charge. My engine has Carrillo H beam rods, which are stronger then I beam and certainly an upgrade. I am also including a full gasket set (head, oil pan, rear main, timing cover, valve cover, etc). On top of that I am splitting shipping, which usually is a deal killer.
Thank you
-Chris
Offline Dukes69
    • Pro Touring Mopar
« Reply #3 on: April 07, 2010 - 08:59:01 PM »
Price is now $3750 shipped and I'm including a 6.1 balancer.
Thanks
