Author Topic: 1974 Barracuda 440 at Infineon Raceway Summit Drags Feb. 15, 2010  (Read 2388 times)
Offline Aracer
This is before the new RPM intake, which will lower et's for next month. Click on the Utube user name (Winterland) for more action that day. :aarg: or subscribe for future uploads.
Offline Oldschool
  • Member Since 9-05-06
Re: 1974 Barracuda 440 at Infineon Raceway Summit Drags Feb. 15, 2010
« Reply #1 on: March 03, 2010 - 10:17:32 AM »
Lookin' good!    :2thumbs:    :burnout:
Ken  --  In Georgia
Offline cudachall74
« Reply #2 on: March 04, 2010 - 08:50:51 PM »
nice work :burnout:
74 barracuda
74 challenger
Offline ireland383
« Reply #3 on: March 04, 2010 - 09:00:13 PM »
Awesome! :ylsuper:
1971 Plymouth Barracuda
Offline Aracer
« Reply #4 on: March 05, 2010 - 12:21:27 PM »
Thank's for your support!
     4.30 axle, DrDiff's lightened  spool, Stock converter (2100-2400) with MP shift improver kit, which blocks the accumulator down, the line pressure adj. out at max, a large aluminum tip (soft apply) kick down, internally blocked, so it's rigid.  4.3 lever, bands on the snug side.
       29"x10" slicks are mandatory at the track.
      Unless you like skating. :bigsmile:
      I just installed the 2" lift leaf set, to prevent the fish tailing, you see after the burnout. Now that the slicks are broken in, the burnouts will be a quick spin to clean the dirt off. The tire pressure will be dropped from 12.5 lbs. to 11, and a higher foot brake rpm, from 1200 to 1800.
      The next Summit race is on April 3.
