Author Topic: Mass-Flo EFI Set-Up....  (Read 710 times)
Offline KMKuda
« on: March 04, 2010 - 09:48:55 AM »
I was looking at possibly turning my old Carb'd Dodge pick-up into a fuel injected set-up. It's got a mild 360 with a mid-size cam/edelbrock heads & intake and was curious if anyone has used the Mass-Flo EFI set up before and what the pro's & con's were.
Is it worth the $$$ for the better driveability / response? Does the system really perform as well as it is hyped??
Has anybody used it in a high HP motor? Just thinking down the road for when I have my 550 hp 383 in the cuda....
Offline Supercuda
Re: Mass-Flo EFI Set-Up....
« Reply #1 on: March 04, 2010 - 09:56:40 AM »
All the modern, plug-and-play EFI systems are good. Mass-flo's system uses a mass airflow meter, as opposed to a manifold absolute pressure sensor, to control fueling. This is an inherently better design for self-tuneability; it requires no re-mapping of fuel or spark curves, and self-learns at a faster rate than a MAP-controlled system can. It is also less sensitive to component changes; a differet intake manifold, headers, or a camshaft upgrade seldom requires any more than a few minutes of driving it to re-learn the fuel curves, so it can use the new parts to their best advantage. I am not knocking the MAP systems, just expressing my preference for the MAF system, and why I like them. I haven't used any of them, but I read about them, and wish I could afford it. You pays your money, and you makes your choice.
« Reply #2 on: March 05, 2010 - 01:59:26 AM »
I converted a 68 RR to EFI , it is a serious 440 engine making over 700 gross hp & it is totally drivable , it idles well & run great , as long as the fuel system will flow enough fuel to support the HP EFI will work great even on very powerful engines
Offline KMKuda
« Reply #3 on: March 05, 2010 - 12:34:49 PM »
Wow...I like the sound of that! Did you go with a kit like the Mass-Flo or did you buy the componants yourself?
« Reply #4 on: March 06, 2010 - 10:12:53 AM »
bought the components from different suppliers , the injectors werew Bosch , the throttle body was a 1200 CFM Accufab , intake was edlebrock victor predrilled with rails , the pumps were Walbro , the computer is a SDSEFI until that comes with a hand held programmer so no laptop is required
