Author Topic: holes on bottom of block  (Read 713 times)
Offline mojavered
  • Someday!
« on: March 04, 2010 - 04:31:06 PM »
Can someone tell me what the holes are for on the passenger side of the block, on the bottom?  Is a 440 block and not sure if they are on all blocks or not???There are 2, one in front and one in the rear.  They are about 3/4" in diameter.  The one in the rear is next to the oil pan and the bell housing.  The one in the front is below the fuel pump.  Sorry I do not have any pics.  I will try and get some if noone chimes in.  Thanks.
« Last Edit: March 04, 2010 - 06:56:03 PM by mojavered »
Jason
Re: holes on bottom of block
« Reply #1 on: March 04, 2010 - 07:45:07 PM »
I don't know about the hole in the back that you speak of, but the front hole should have a big Allen head plug in it. The purpose of that hole is to allow you to remove the pushrod for the fuel pump after you remove the fuel pump from the block. They do wear down over the years, so it just falls out that hole once the pump is removed.
Offline mojavered
  • Someday!
« Reply #2 on: March 04, 2010 - 08:10:14 PM »
I had to steal these pics from a Mopar Muscle article, but you can see in the pic the holes I am talking about.  They are outlined in a yellow ring.  You can only see the hole in the back of the block if you are under the car.  Thanks.
Jason
« Reply #3 on: March 05, 2010 - 02:02:34 AM »
possibly to hold the block while being machined or removed from the mold . They all have them
« Reply #4 on: March 05, 2010 - 08:31:17 AM »
Tooling holes for machining when it was a casting
Offline mojavered
  • Someday!
« Reply #5 on: March 05, 2010 - 10:15:10 AM »
Thanks.  When I was under the car, I saw that hole and thought that I needed to put some type of plug in the rear one, that it might go all the way into somewhere???  I guess not though, Thanks.
Jason
