Author Topic: Deck height and compression  (Read 1306 times)
Offline Strawdawg
    • Vortex Buicks
Re: Deck height and compression
« Reply #15 on: March 05, 2010 - 10:15:15 PM »
deleted due to faulty computations from incorrect compression calculator...
« Last Edit: March 06, 2010 - 08:08:01 PM by Strawdawg »
Offline Strawdawg
    • Vortex Buicks
« Reply #16 on: March 05, 2010 - 10:50:02 PM »
The ideal solution, imo, would be to bolt on a set of closed chambered aluminum heads which will eliminate the quench problem, and, being thermally less efficient, will also eliminate any concerns with pump gas.
Offline Strawdawg
    • Vortex Buicks
« Reply #17 on: March 06, 2010 - 12:01:40 AM »
how do you have quench with an open chamber head?  The combustion chamber is recessed at least .100" at all points, I believe. :)
« Last Edit: March 06, 2010 - 12:03:18 AM by Strawdawg »
Offline AMXguy
« Reply #18 on: March 06, 2010 - 12:33:42 AM »
I'd be totally happy with 9.88.
 The timing events on my card are .050 9.5 41.5 49.5 1.5 , I don't have a clue what those numbers mean. I have this cam in my six pack Challenger and it runs and sounds great, same pistons too but I don't have any idea what the deck height is so I can't say what the compression ratio is.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline Strawdawg
    • Vortex Buicks
« Reply #19 on: March 06, 2010 - 12:44:37 AM »
the link straw posted doesnt factor in head gasket bore size and the true compression will be 9.88 with .060/4.410 gasket
.045 quench is very very good. not a problem at all  :working:
id still like to know the cam timing events.......
old school calculator says 9.99 which is pretty close to your number...must be old math vs the new math :)
Offline moper
« Reply #20 on: March 06, 2010 - 12:42:34 PM »
As said... 906s are open chamber and deep. I have zero deck quench domed KBs that stick up .070" above the deck. I have to mill the heads (452s) .040 to get quench down to .040. So the chambers are .110" deep. On yours .015" will not give you any quench, and you could run the steel shim .18" and have plenty of piston to head clearance.
