Author Topic: Question on 90* oil filter adapter position.....  (Read 482 times)
Offline Glennster
« on: March 04, 2010 - 07:56:33 PM »
Does the hole I'm pointing at have to be lined up with the hole on the engine block to get correct oil flow?
Does the position of the adapter matter at all?
I'm trying to get it to work with my Hooker headers.
Is it OK to go to a smaller oil (K&N) filter? I think that's the only way I can use the 90* adapter, the fatter oil filter won't fit.
Re: Question on 90* oil filter adapter position.....
« Reply #1 on: March 05, 2010 - 06:44:25 AM »
You can spin the filter relocator in any direction that gives you best access and clearance
