Nothing should be run with stock springs IMO. Certainly not a performance oriented cam. As Neil said you can look at Lunati which have some good grinds but all require dual springs which means machining on the heads. If you want to stay MP (and I personally wont for quality control reasons) then you'll have to get an MP general performance spring to use with it. A nice bacis easy package would be the Summit brand smaller cam and Comp 901-16 springs. Basically all drop in for you and the cam, lifters, springs, and gaskets should be under $350.
