Author Topic: 307/308 cases  (Read 993 times)
Offline Bobfish
307/308 cases
« on: March 06, 2010 - 01:08:51 AM »
Question One.... Whats the difference between the 307 and 308 cases and how can I tell them apart?? Casting #'s?? Thx, Bob
Offline Changin Gears
Re: 307/308 cases
« Reply #1 on: March 06, 2010 - 07:37:30 AM »
I just look at the hole that the bearing goes in with my calibrated eye.  Don't know about casting numbers but, if  its an aluminum case, chances are its an OD case with foating counter shaft which I don't like.
Offline Bobfish
Re: 307/308 cases
« Reply #2 on: March 06, 2010 - 11:57:58 AM »
So your saying they have a different input shaft bearing??
Re: 307/308 cases
« Reply #3 on: March 06, 2010 - 02:29:38 PM »
Right, the 18 spline trans and some of the 23 spline big block trans used the 308 bearing.  All the small block (non-OD)  trans used the 307.
Offline Bobfish
Re: 307/308 cases
« Reply #4 on: March 06, 2010 - 03:16:57 PM »
Would I be corret then in infering ( not assuming!) that OD cases were 308?? Bob
Re: 307/308 cases
« Reply #5 on: March 06, 2010 - 09:53:31 PM »
I believe so, all the ones I have seen are.
Offline rallye73
  • Model cars for the big boys!!
Re: 307/308 cases
« Reply #6 on: March 07, 2010 - 01:48:54 AM »
I think my trans had both the 308 and 307 in it. I'd have to ask the  guy who rebuilt it. Pretty sure that's what he told me. The original 308 bearings made by SKF are not longer made. I think Passon snatched up all the remaining one out there. What is left is chinese bearings which I wouldn't use unless I absolutely had too. We got lucky and found a couple of the SKFs still out there. BTW my trans is a 23 spline none-OD small block.
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
Re: 307/308 cases
« Reply #7 on: March 07, 2010 - 07:38:21 AM »
All A833's have 2 of the 307/308 bearings.  The one in the main case is the one discussed so far.  There is another in the tailhousing.  A/F bodies use the 307, B/E bodies use the 308.
Offline Bobfish
Re: 307/308 cases
« Reply #8 on: March 07, 2010 - 04:14:03 PM »
Do either of you have the SKF,OEM or other 308 part numbers  I can use for a cross reference to Timken, BCA, INA, Ford, GM, AMC etc?? Sometimes ya never know what ya can find out there! AND yes Ford, GM, and Chrysler did use some of the same parts. Thx Bob
Re: 307/308 cases
« Reply #9 on: March 07, 2010 - 05:24:42 PM »
307/308 is the part number, with different suffixes or prefixes for # of balls, with/without snap-ring groove etc.
By the way GM actually used the a833 behind diesels in trucks in the 80's.  They have the GM input shaft and bolt pattern.
